Pressure In Holding Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-28-2016, 03:12 PM   #1
Rewards Points: 155
Pressure in Holding Tank
The pressure in my holding tank which is in the cottage is always 10psi lower than what it is at the pump, which is down at the lake 200' away. The cut-in pressure of the pump is 30psi (pressure switch is on pump), so the pressure at the tank would be at 20psi at cut-in. My question is, since dry pressure should be 2psi less than cut in pressure, what should the pressure in my tank be when dry, 18psi or 28psi? Thanks
wilyum is offline   Reply With Quote
Old 05-28-2016, 06:34 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,578
Re: Pressure in Holding Tank
18psi.
Is the pump lower than the tank? A 10 psi difference could be from a 20 foot rise from the pump to the tank.
Or one of the pressure gauges could be defective.
Old 05-30-2016, 06:28 PM   #3
Rewards Points: 155
Originally Posted by joed View Post
18psi.
Your right the pump is lower, probably about 50' lower than the tank. Ill lower it from 28 to 18. Its been like this for a month, would there have been any damage?
captive air tank and water pressure bobcatnj Plumbing 6 05-12-2014 09:55 PM
Need Help on Well Pressure Tank Layout osubuckeye88 Plumbing 16 02-04-2014 06:02 AM
Well pressure tank operation........need some opinions JayBird Plumbing 5 12-27-2011 04:36 PM
New Well, Pump & Pressure Tank Design Daneel Plumbing 0 06-07-2011 03:28 PM
Well Water Pressure Tank for Air? Reilley Plumbing 8 02-20-2009 12:53 PM
