Pressure Drop From Kitchen Sink - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By jmon
Old 06-23-2016, 11:52 AM   #1
Rewards Points: 42
Question
Pressure Drop from Kitchen Sink
Hi all- just moved into a fairly new (only 3 years old) house, and having issues with the water pressure dropping at the kitchen sink. The water runs fine, but then after a couple minutes, the water pressure drops (regardless of whether it's hot or cold).
We don't notice the issue from any of our other fixtures, but still trying to determine whether it's the faucet itself (cartridge?) or an issue downstream somewhere. If there was an issue with the sink itself, wouldn't it have lower pressure all the time, instead of starting out at normal pressure? Here's a video of what happens:
Any insight or things to check for would be appreciated, thanks!
fiveomar is offline   Reply With Quote
Old 06-23-2016, 02:02 PM   #2
Rewards Points: 3,220
Re: Pressure Drop from Kitchen Sink
Check to see if you are still under waranty from builder first. Let them do it.
If not, Its isolated to just this faucet, so check the obvious things first.
Turn water off to supply lines, remove each supply line, hold into bucket turn water back on make sure you have good pressure. If not, replace supply lines.
Make sure aerator/cartdrige is clean. From the video it sounds like sediment build up in aerator or cartdrige. May just need a good cleaning/flushing.
See if there is a water saver washer in the aerator that can be removed. Just a few suggestions.
r0ckstarr likes this.
jmon is offline   Reply With Quote
Old 06-23-2016, 02:50 PM   #3
Rewards Points: 2,560
Is your water supplied from city or a well?
Do you know if you've a pressure reducing valve in the supply line?
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Ghostmaker (06-23-2016)
Old 06-24-2016, 10:28 AM   #4
Rewards Points: 42
City of Philadelphia supplied. Not sure about a pressure reducing valve, where do those typically sit? And wouldn't that be constant, rather than normal pressure which then drops?
To the other poster- we are the second owners of the home, so don't have a warranty from the builder. Thanks for the other suggestions- will try those.
The Following User Says Thank You to fiveomar For This Useful Post:
jmon (06-24-2016)
Old 06-25-2016, 05:06 AM   #5
pressure reducing valve likely is near where the water supply from street comes in. I believe these can sometimes go "bad" to cause this kind of effect. But if only 3 years old unlikely.
It looks like this: http://www.homedepot.com/p/Zurn-Wilkins-3-4-in-Lead-Free-Bronze-Water-Pressure-Reducing-Valve-with-Double-Union-Female-Copper-Sweat-34-70XLDUC/203999031?cm_mmc=Shopping%7cTHD%7cG%7c0%7cG-VF-PLA-D26P-
Plumbing%7c&gclid=CPWs3oP2ws0CFUpahgodXtMINg&gclsr c=aw.ds
I have a similar issue that isn't as pronounced as your drop. Have you asked one of your neighbors to see if the same thing happens to them?
Drop in water pressure Mdwdirect Plumbing 8 01-24-2013 08:56 PM
TPR valve leaking - closed system? Hidden check valve? Pressure mystery dustout Plumbing 0 09-23-2012 05:36 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Kitchen sink hot water pressure weak n0c7 Plumbing 2 02-14-2010 11:40 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
