Power Vent Water Heater Making Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2015, 06:37 PM   #1
Lord of Slums
Rewards Points: 1,974
Power vent water heater making noise
I had a Bradford white power vented water heater put in a few months ago. It seems that the power fan is making a noise throughout the house. When I stand right next to the heater the fan sounds fine. But it makes this whirling noise through the house. I do not want my plumber thinking I am a nut case. It is somewhat annoying. Should those blowers be silent?
Anyone know how warranties work? I paid him to install the heater, he supplied the heater.
mj12 is offline   Reply With Quote
Old 08-27-2015, 07:22 PM   #2
Rewards Points: 3,430
Yes they can be noisy. Check and make sure that nothing is obstructing the vent. No screens. bugs, critters, etc. Just a suggestion.
Explain to him whats going on and have him come out and make sure everything is working correctly. It's possible it could have went bad. Not likely though. At only 3 months old, I'm sure it's still under warranty if needed.
Others will be along with more suggestions.
jmon is offline   Reply With Quote
Sears Economizer 6 Power Vent Water Heater jagans Plumbing 17 06-01-2013 07:45 PM
Decaying brick chimney needed to vent water heater elwood33 Building & Construction 5 05-23-2013 08:44 AM
Water heater, atomospheric vent or power vent? abefroman Plumbing 5 01-24-2013 10:56 AM
Water Heater blowing out Power to Entire House tbigley Electrical 5 03-02-2011 02:54 PM
