Power Vent On Water Heater Continually Runs - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2016, 02:04 PM   #1
Rewards Points: 78
Power vent on water heater continually runs
I noticed over the last couple of days that the power vent on my gas water heater is running all the time; even when the water heater itself isn't on. Is there a switch or relay that triggers the fan that has maybe gone out? Otherwise the water heater itself has been working fine.
Retiredchief is offline   Reply With Quote
Old 06-03-2016, 04:22 PM   #2
Rewards Points: 3,220
Re: Power vent on water heater continually runs
Yes . depending on manufactuere, probably safety switch relay stuck. Maybe an obstruction in hose. You can try tapping on it and make sure no obstructions.
Whats the model number of water heater and power vent.
jmon is online now   Reply With Quote
Old 06-03-2016, 05:07 PM   #3
Rewards Points: 78
It's a Fasco power vent P/N 0012400500 type U21B
And a State Select water heater model looks like PR650NOVT
Old 06-03-2016, 08:05 PM   #4
I am not familiar with that brand of water heater. I'm sure someone on this forum is familiar with it. Try going online and giving them a call and ask them directly.
Check operators manual under troubleshooting; I did a google search and think I found operators manual in case you no longer have it.
http://www.manualslib.com/manual/165...50.html#manual
Gas water heater vent too short? Ginny28 HVAC 6 05-04-2016 09:00 AM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Power Vent Water Heater Replacing Draft Vent polebarn HVAC 13 03-28-2012 06:12 PM
Rheem Power Vent 2 Water Heater jrf0022 Plumbing 3 09-25-2011 05:06 PM
