Polyplumb Installation - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree4Likes
  • 3 Post By ddawg16
  • 1 Post By getrex
Old 12-10-2016, 02:15 PM   #1
Rewards Points: 2
Question
Had new heating, hot water system and pipe work installed using Polyplumb push fittings.
I should be concerned that the pipes and connectors look like they are under stress. see attached photo.
What does the manufacture specify?
Will they have a high chance of leaking over time?
thx all
huboutsailing is offline   Reply With Quote
Old 12-10-2016, 02:19 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 24,924
Re: Polyplumb Installation
Not familiar with Plumb.....but, the above looks like crap.
ddawg16 is online now   Reply With Quote
Old 12-10-2016, 04:14 PM   #3
Rewards Points: 18,998
Where are you that there still using using what looks like Quest tubing?
Why is the plumbing not run through the studs and not face mounted?
Sure looks like a first time DIY install to me.
No way it should be run at an angle like that!!
Old 12-10-2016, 09:58 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,102
Your profile doesn't show location but the only Google returns I found for Polyplumb were from the UK. If so, the majority of contributors on this site may have no idea what the specs are for this product. I will assume it is approved for domestic supply in your jurisdiction.
None of which takes away from the observation that it looks like it was installed by a chorically-unemployed second cousin.
lenaitch is offline   Reply With Quote
Old 12-11-2016, 09:25 AM   #5
Anonymous Tard
getrex's Avatar
Rewards Points: 16
Wow... just.. wow. My sympathies.
getrex is offline   Reply With Quote
Old 12-15-2016, 10:43 PM   #6
Rewards Points: 80
I've never used polyplumb. We use sharkbite and other manufactures here. The plastic versions do leak when not done just perfect. Sharkbite is slightly more forgiving.
With that said, those elbows... As odd as they look, are probably OK.
I dunno anything about the sizing for that stuff. Some of it does look smaller then the rest, which seems off.
My next question is.... How on earth is the wall finishing going on?
Good luck.......
Cheers!
supers05 is offline   Reply With Quote
Old 12-16-2016, 04:52 PM   #7
Anonymous Tard
getrex's Avatar
Rewards Points: 16
The only way to finish that wall is to build out the studs more. But that is assuming that they are going to finish it.
supers05 likes this.
Victim of improper Roofing installation. tbirleffi Roofing/Siding 9 06-06-2013 10:45 AM
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 06:42 PM
Kitchen and Living Room Installation bejscott Insulation 1 08-10-2012 12:18 PM
Found Roof Rot due to installation errors after labor warranty expired OneTripper Roofing/Siding 7 06-24-2009 02:59 PM
