Plumbing Under Slab For New Shower. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2015, 08:59 AM   #1
Rewards Points: 527
Plumbing under slab for new shower.
I've got a contract to buy a 1970 slab-on-grade ranch in Virginia Beach with 1.5 bathrooms. The 1/2 bath is in the master. Hoping to somehow squeeze a shower in there. That has me wondering about the new plumbing that needs to go through and below the slab. Can the shower drain tie into the existing toilet drain sub-slab? Does shower drain have to be vented? How do you ID exiting utilities before cutting into the slab. Is there a good video to watch. Thanks.
Posted in Remodeling as well. Not sure which is more appropriate.
LarryJ-nova is offline   Reply With Quote
Old 09-03-2015, 09:42 AM   #2
Rewards Points: 5,348
All drains should be vented
You should find out if your slab is , "pre tensioned". Cutting into the rebar can cause issues with those slabs.
Ron
B. Franklin 1759
Old 09-03-2015, 10:55 AM   #3
Rewards Points: 527
Thanks for the reply. Good call regarding slab, but I think you mean post tension slab, not pre-tension. I did some reading on post tensioin slab. Couldn't find any info regarding pre-tension slab, but found some regarding prestressed concrete. Will continue the research and will look at garage floor to see if there is a "post tension" stamp warning of no drilling allowed.
Old 09-03-2015, 12:21 PM   #4
Seems I got a little ahead of myself.
Ron
B. Franklin 1759
Should I cut the slab and replace all our bathroom plumbing? darsunt Plumbing 8 06-07-2014 10:05 PM
Shower Plumbing Advice? ddawg16 Plumbing 17 08-31-2011 10:17 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
which way to route shower plumbing? everyman Plumbing 11 03-04-2009 08:10 AM
Installing a one piece shower... plumbing issues singforsupper Plumbing 2 06-01-2005 08:26 AM
