Plumbing Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2015, 12:33 PM   #1
Rewards Points: 369
Plumbing rough in
Pretty sure I know the answer to this but figured I'd check anyway.
Typical rough in always has the drain in the center and the supply on either side. Is there anything that says I can put both supplies to one side?
I ask because if I can put both supplies on the one side of the drain it will free up space in my vanity design for wider and more useful drawers.
info2x is offline   Reply With Quote
Old 01-31-2015, 01:55 PM   #2
Rewards Points: 1,932
Have a blast.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
BlackTiger (01-31-2015), info2x (01-31-2015)
Old 02-02-2015, 11:19 AM   #3
Special User
Rewards Points: 1,230
I'll be doing this myself shortly. I offset the drain a bit to the left to miss the vanity light electrical box, so will be putting both supplies on the right where a convenient stud is located.
Don't forget that hot still goes on the left of the cold, though.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 02-02-2015, 12:50 PM   #4
Rewards Points: 1,336
I have one house where they are stacked. The way the access inside the wall worked out and the cabinet design allowed me a 2" area at the edge of the cabinet to get the supply's in. I put the bottom one out farther than the top one to allow for the supply tube hookups. The drain was the trickier part. I had to run the trap assembly to a stub-out behind the drawers. Fortunately there was ample room between the back of the drawers and the back of the cabinet.
danpik is offline   Reply With Quote
Rough in plumbing pre test? 1dumbquestion Plumbing 2 01-20-2012 08:12 PM
Installing Plumbing in a basement with No rough ins simpsjm1 Plumbing 8 12-20-2011 10:40 PM
basement plumbing rough in smacameron Plumbing 3 11-20-2011 05:34 PM
basement plumbing rough in - what are these pipes? skypilot84 Plumbing 1 10-12-2010 11:59 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
