Plumbing Remodel, Currently Have A 1/2" Main Supply, HELP! - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2015, 09:36 AM   #1
Rewards Points: 6
Plumbing remodel, currently have a 1/2" main supply, HELP!
First time poster, go easy :-)
Recently purchased my first home (vintage 1949), and it has a 1/2" copper main water supply coming into the house. It passes through the meter where it then switches to 3/4" for about 16 feet, then branches off into two 1/2" lines, one acts as the cold water trunk, one to the hot water tank. I suspect this to meet local code, in Ontario it seems you have to run 3/4" pipe until the hot water tank, then you are allowed to reduce it. I suspect the previous home owner upgrade his plumbing at one time and this is what they did to pass inspection????
Current Setup
1/2" > water meter > 3/4" > 1/2" "Y" branch (one acts as the trunk for the whole house, one goes to hot water tank
I am looking to remodel the basement and was wondering how I should change this. Currently, if I use more than one fixture in the house the pressure will significantly drop on whichever line I am using.
I would like to avoid having to replace the main supply coming into the house, and I have looked into switching over to a manifold system. Although I have found very little evidence that this will in fact solve my problem.
Any suggestions would be appreciated.
swhip is offline   Reply With Quote
Old 02-06-2015, 09:50 AM   #2
Rewards Points: 127
Half inch main? That's the problem. You will need to fix that first. I suspect your inside plumbing is fine once you fix the supply.
jimn01 is offline   Reply With Quote
Old 02-06-2015, 10:08 AM   #3
Rewards Points: 6
I was hoping you would not say that... So in essence it's useless to even think about 3/4" trunk or manifold until I fix that.
Old 02-06-2015, 12:29 PM   #4
1/2" supply?!?
Going to a larger diameter pipe, is not going to do much good!
(1/2" supply???!!?!)
Don't know where you're at - new supply, around here -
$3000 to $5000.
Are you on a well?
rossfingal is offline   Reply With Quote
Old 02-06-2015, 01:15 PM   #5
Rewards Points: 6
Originally Posted by rossfingal View Post
1/2" supply?!?
$3000 to $5000.
Are you on a well?
No I am not on a well.
Still wondering if a manafold (e.g. Viega Manabloc) will help minimize the the temperature fluctuations I am currently seeing. Has anyone had any experience with them, good or bad?
Old 02-06-2015, 02:20 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 258
To properly size water service and the inside piping you need to know the water fixture unit demand and your water pressure.
Each plumbing fixture has a WFU value assigned to it- available online.
Once you know these you can also use online charts to arrive at the proper pipe sizes.
Not knowing these will only lead to guessing and hoping the pipe is large enough..
Generally speaking, 1/2" service is no longer allowed. 3/4 or 1" is more standard
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (02-08-2015)
Old 02-06-2015, 03:37 PM   #7
Rewards Points: 1,414
One thought (that may be wrong)--You might also be able to do something with a water pressure booster and/or pressure tank, if you wanted to avoid digging up the main line at the moment.
Tom738 is offline   Reply With Quote
Old 02-07-2015, 10:32 PM   #8
Bob Sanders's Avatar
Rewards Points: 2,536
Common problem in older houses. My house is 100 years old and the supply is 1/2 inch as well.
Using pressure balanced shower valves helps to avoid people getting burnt while showering at the same time some one flushes a toilet. Other than that you pretty much have to live with it unless you feel like digging up the line.
Your house although not up to present code with a 1/2 inch main, is grandfathered in so there is no legal need to replace the line. Though if you do remodel, all new installs must be code worthy after the 1/2 inch main
Bob Sanders is offline   Reply With Quote
Old 02-07-2015, 10:42 PM   #9
Rewards Points: 268
I also have a 1/2" supply. My house was built in 1914 and the copper isn't the original, but for some reason (probably in the 70's) they ran 1/2" copper when they replaced the old.
We live with it...not all that bad. Takes forever to fill a kiddie pool in the summer, though.
Marqed97 is offline   Reply With Quote
Roughed in Plumbing Under Main Air Duct DIY33 Plumbing 5 11-26-2012 11:15 AM
plumbing supply line mitramarket Plumbing 4 08-27-2011 02:35 PM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Bathroom remodel. New Shower Plumbing s4alex Plumbing 5 10-14-2008 06:40 PM
Ground Main Water Supply? blueboy27 Electrical 17 11-04-2007 12:38 AM
