Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2016, 02:10 PM   #1
Rewards Points: 4
Plumbing Question
I have done my share of very basic plumbing in the past. I was swapping out a toilet today due to repeated clogging of a builders grade toilet. This is a newer house I recently purchased and the plumbing is drastically different looking than anything I have seen or worked with before.
I am specifically interested in the drain configuration for the toilet waste pipe.
After removing the toilet I noticed this waste pipe configuration I had not seen before when removing toilets. I feel like this drain configuration would be set up for routine clogs.
Can anyone shed some light into whether or not this is correct plumbing or if this is the actual issue vs the toilet? I dont want to reinstall the toilet if this will continue causing issues.
The primary issue we saw was routine clogs which were easily cleared with a plunger. There is also a stand up shower adjacent to the toilet which occassionally has toilet odor coming from the drain.
This will not add a photo to the text since this is my first post but the photo is available in my album to the left.
Thanks everyone!
skwashie is offline   Reply With Quote
Old 04-23-2016, 02:45 PM   #2
Rewards Points: 4
Toilet Waste Drain Problem
[IMG][/IMG]
Thanks everyone!
Old 04-23-2016, 03:26 PM   #3
Rewards Points: 198
Re: Plumbing Question
Thanks everyone!
Looks normal to me but I do not use wax rings with the 4x3 plastic reducer built into the wax. The reason is that many low flush toilets are designed to drop water very quickly and the plastic interferes with the flush, hence the 4" Flush Valve, unlike the older toilets that sometimes had a 2 1/2" or 3" flush valve which prevented a good flush with smaller amounts of water i.e. 1.2 Gallons per flush or less. Just use plain old wax rings and use 2 if you have a low closet ring that needs to fill the void with wax. I stack them when needed and push them down onto the closet ring being careful to make the opening wider so it does not fall down into the closet bend but stays under the toilet bolts area for a good seal.
srloren is offline   Reply With Quote
Old 04-23-2016, 05:11 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 170
I merged your 2 threads together--
The image shows an unapproved heel outlet 90- at least unapproved per UPC.
The 90 should be replaced. Do you have a crawl space or basement access there?
The Following User Says Thank You to TheEplumber For This Useful Post:
plumberinlaw (04-24-2016)
Old 04-23-2016, 09:33 PM   #5
Rewards Points: 1,854
Cute not legal under IPC either. Because they clog easily.
Ghostmaker is online now   Reply With Quote
Old 04-23-2016, 11:00 PM   #6
Rewards Points: 198
Can't explain why I did not see that...just to quick on the draw.
Old 04-24-2016, 10:52 AM   #7
This fitting is basically a sanitary tee in your case they have it on it's back which is not an approved use of this fitting. Your toilet coming off the top or side of the tee on its back.
Kitchen sink plumbing question Lin171 Plumbing 30 07-19-2015 06:29 AM
Very basic question on plumbing an airgap Crank Plumbing 3 03-06-2014 09:09 PM
Hello All! I have a plumbing career related question jelliott25 Plumbing 5 12-15-2013 03:32 PM
plumbing career question greaselightning Plumbing 25 06-11-2012 03:30 AM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
