Plumbing /Irrigation - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-03-2015, 07:58 PM   #1
Rewards Points: 20
My house has cinderblock walls with my sewer plumbing exiting through a hole at the foundation,and the hole is so close to the ground on the outer wall that water is coming through the hole when it storms real bad..I was wondering what i can use to seal the hole around the sewer pipe but be able to remove sewer pipe if i need to repair or replace said pipe (pvc),the hole is 3 inches bigger than the sewer pipe..
Davidh8 is offline   Reply With Quote
Old 07-03-2015, 09:44 PM   #2
Rewards Points: 3,430
Use hydraulic cement to seal around it.
Worst case, down the road, you can chip it out.
Been there, done that.
ktkelly is offline   Reply With Quote
The Following User Says Thank You to ktkelly For This Useful Post:
Davidh8 (07-04-2015)
Old 07-04-2015, 04:45 PM   #3
Rewards Points: 1,938
They should have used a sleeve and a donut. Since that was not done try spray foam in a can. The expanding type.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 07-04-2015, 04:59 PM   #4
Rewards Points: 20
I know..Thats not the only mistakes that i have found around here either,simple mistakes makes even bigger problems for me lol
Old 07-04-2015, 05:00 PM   #5
Rewards Points: 20
Thanks ill try the foam on same problems around here as to i have already bought hydraulic Cement at Lowes
Old 07-04-2015, 05:02 PM   #6
Rewards Points: 20
Thank you
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 11:50 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
moisture under slab, roughed-in plumbing bergerdude Building & Construction 4 03-25-2011 08:29 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
