Plumbing Help? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By chandler48
Old 08-27-2017, 11:52 AM   #1
Rewards Points: 18
Plumbing Help?
I have 2 1/2 baths. This smell is coming from the cold water lines only in both master bath sinks. They have separate cutoffs underneath but I think they use the same supply line. When you turn on the cold water it smells like sewer for about 15 seconds. Happens in both sinks in the master bath but no where else in the house. I have cleaned the overflow in both sinks with vinegar and baking soda. Aerators are ruled out as it doesn't occur with hot water lines. I am on a well with a Culligan softener. Traps are clean. I am totally perplexed and hope someone can help. Thanks in advance.
jrhuggs is offline   Reply With Quote
Old 08-27-2017, 12:28 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,652
Re: Plumbing Help?
We've ridden this horse before. Won't help duplicating it as we read them all. Hopefully the right person will pick up and will have the answer.
http://www.diychatroom.com/f7/bad-sm...s-only-537409/
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-27-2017, 01:52 PM   #3
Rewards Points: 18
Re: Plumbing Help?
I tried sending you a message as I had answered your question. I had also added to the post and received no reply. Not replying made me believe you had left me. Simply stating you don't know the answer and/or chiming in to see if there's any others may help to give faith that one hasn't been deserted. So, I duplicated to see if maybe others had a response. Thanks....
Old 08-30-2017, 10:08 AM   #4
Rewards Points: 18
Re: Plumbing Help?
Hi,
try a plunger and or a singe use "zip-it" drain cleaner first. They look like long plastic sip ties with barbs along the sides.Just to check for the blocked drains It'll really depend on what's clogging it. You can dumping some baking soda followed by white vinegar down the drain first. The foaming action may loosen up some stuff. I'd try this a few times.
If it's more tougher stuff like hair you can try buying one of those drain snake things to help remove.
Otherwise, it's a call to the plumber.
dereklotts is offline   Reply With Quote
Old 08-30-2017, 04:36 PM   #5
Naildriver
chandler48's Avatar
Re: Plumbing Help?
Dereklotts, his problem is with supply lines not drains, as evidenced in the other thread.
jrhuggs likes this.
Larry......
Old 08-30-2017, 06:22 PM   #6
Rewards Points: 1,948
Re: Plumbing Help?
Your well is contaminated with sulfur bacteria.
http://www.health.state.mn.us/divs/e...rosulfide.html
read up on it
Old 08-30-2017, 06:56 PM   #7
Rewards Points: 110
Re: Plumbing Help?
I agree with dereklotts that it is a drain issue, if not a clog, maybe a vent issue like the smelly sink problem last week. Otherwise, the water should smell in the rest of the house also.
Sub
subbuilder is online now   Reply With Quote
Old 08-31-2017, 04:37 AM   #8
Naildriver
chandler48's Avatar
Re: Plumbing Help?
Guys, see the link in post #2. It is well explained in that thread and the OP is adamant that the smell is not from the drain. That was my first conclusion, too. THAT's why we don't duplicate threads. Too much information is lost.
Larry......
How to frame for faucet plumbing and a medicine cabinet Maker Remodeling 1 07-26-2016 06:34 PM
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 11:50 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
