Plumbing Half Bath - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2017, 11:09 AM   #1
Rewards Points: 4
Plumbing half bath
So we decided to scrap putting in a full bath. I want to join this into main sewer line. Can I connect the sink with 2" and the toilet with a 3".
skarns is offline   Reply With Quote
Old 03-10-2017, 11:19 AM   #2
Rewards Points: 4
I forgot to mention this is in the basement and space is limited. Can not connect 2" into the 3" unless we reconfigure bath
Old 03-10-2017, 11:20 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 248
Re: Plumbing half bath
If you are piping a lav, you can use 1.5" You can also pipe the lav off the 2" toilet vent (wet vent) if configured properly. Your toilet venting looks a little off. But that may just be the picture...
Old 03-10-2017, 11:32 AM   #4
Rewards Points: 4
Ok, could I use 2" on the lav, and let that wet vent my toilet? Or is that wrong
Old 03-10-2017, 11:46 AM   #5
Rewards Points: 4
The toilet and sink Drain will be about 4' apart
Old 03-10-2017, 01:55 PM   #6
Rewards Points: 4
If I wanted to add a shower beside the toilet would I run a 2" line into the 4" with ptrap and vent it out 2"
Old 03-10-2017, 05:12 PM   #7
Rewards Points: 1,932
A wet vent cannot have the entire house drainage flowing through it.
Old 03-10-2017, 10:48 PM   #8
Rewards Points: 4
Could I vent the toilet to the main stack with 2" vent
Old 03-11-2017, 02:58 PM   #9
A vent has no drainage coming down it from above.
Tile layout for half bath Troy32 Tiling, ceramics, marble 10 12-14-2016 10:12 PM
new bath tub installatioon question about plumbing federer Plumbing 205 10-05-2014 08:31 PM
Half Bath Reno tb151 Project Showcase 10 05-21-2013 11:15 AM
Removing master half bath to extend main bath ryanb4614 Plumbing 18 08-27-2011 07:21 AM
master bath plumbing problems terri little Plumbing 1 07-12-2007 06:45 PM
