Plumbing On Exterior Wall In SoCal - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2017, 10:47 AM   #1
Rewards Points: 2
plumbing on exterior wall in SoCal
Hi,
I live in Southern California (OC) have plumbing on the exterior walls of my house. Does anyone know at what temperature pipes start to freeze?
A couple nights a year it might reach 30 degrees here, and we've had a record low of 25 degrees once. Is this something I could be worried about?
Thanks.
bearflag is offline   Reply With Quote
Old 02-11-2017, 11:05 AM   #2
hkstroud's Avatar
Rewards Points: 6,694
Re: plumbing on exterior wall in SoCal
Water freezes at 32 degrees Fahrenheit.
You should have not concerns about pipes bursting due to freezing.
Harold,
The Left Handed Widget Maker
hkstroud is offline   Reply With Quote
Old 02-11-2017, 04:32 PM   #3
Rewards Points: 6,596
Water supply pipes can be on exterior walls at most any inhabitable temperature if the pipes were placed to the interior side of the insulation , assuming the structure's exterior walls are insulated. Supply pipes on the wrong side of insulation ? all bets are off at temps. less than 32F.
SeniorSitizen is offline   Reply With Quote
How to frame for faucet plumbing and a medicine cabinet Maker Remodeling 1 07-26-2016 06:34 PM
1st-time home buyer novice plumbing renovation question dakotajoe Plumbing 6 06-28-2011 11:50 AM
Bath remodel in 1947 house -- questions about plaster and plumbing Alix Remodeling 7 06-06-2011 09:12 PM
Plumbing Disasters Contest - Win a TOSCA Faucet for your Kitchen! Nathan Plumbing 48 07-06-2010 07:55 PM
