Plumbing Design Input - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2016, 03:48 PM   #1
Rewards Points: 38
Hi All,
I'm preparing to build my house and have developed the plumbing design and wanted to get some input. I'd appreciate if anyone had input on whether there are any concerns with the design or other things to think of with the design.
Thanks in advance!
pjbadding is offline   Reply With Quote
Old 03-13-2016, 05:52 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 290
Re: Plumbing Design Input
Which code is used in your area?
Old 03-13-2016, 06:00 PM   #3
Rewards Points: 38
Originally Posted by theeplumber View Post
which code is used in your area?
irc 2009
upc 2009
Old 03-14-2016, 09:15 PM   #4
Plumber
Rewards Points: 290
You're missing some vents in different areas for UPC.
You mentioned IRC- that has a different plumbing code in it. Is your town combining the 2 codes?
2009 UPC does not allow horizontal wet venting- unless it has admendments
Old 03-14-2016, 11:37 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 1,012
recommend you pipe them in in groups / branches,
but as Mr E has stated depends on your code.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-15-2016, 05:06 PM   #6
Rewards Points: 582
as E mentioned.. need to know which code applies to your area..the lay out you posted has quite a few vent issues.. reguarding horizontal wet venting..and the lack of venting...
Old 03-19-2016, 09:57 PM   #7
Rewards Points: 38
I'm in Franklin County, MO and there website states the following codes are used:
International Building Code 2009
International Residential Code 2009
International Mechanical Code 2009
International Plumbing Code 2009
I have taken the master bath and re-drawn the isometric to gather further input. Please take a look and let me know if this design works. I'm not sure the vent off each fixture is needed in this design. The distance between the SH and WC is 12 feet.
Old 03-20-2016, 10:10 PM   #8
Rewards Points: 1,952
Your under IPC I'll look at it tomorrow after work. IPC DOES NOT allow any dry flat vents for fixtures. For example your shower can vent the toilet but the shower vent must be vertical. Also if you have more then 4 shower heads you need to upsize to three inch the shower trap and drain.
Your half bath you need to vent the toilet with the lavatory in the same bath off the toilet line in that bath.
I hope you get the idea but you cannot drain any fixtures other then wet vent fixtures on a wet vent. Toilet, Bidet, Lavatory sink tub or Shower and a floor drain located in the bathroom. NOTHING ELSE.
Good night and redraw this.
By the way you also cannot use sanitary tees that receive drainage in any other position then vertical.
Add a clean out on the base of your stack.
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Peninsula Sink removing Pony wall becomes Island Plumbing? lothia Plumbing 6 04-30-2013 12:13 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
