Plumbing Book Reccomendations - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2016, 05:35 PM   #121
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,710
Originally Posted by patrickpresti View Post
Ghost,
.....that 3" pipe, I am going to have no choice to drill a hole through a 2x8 floor joists ..
This is where boxes in the ceiling come into play. Drop it down below the joists.
123pugsy is offline   Reply With Quote
Old 01-31-2016, 05:53 PM   #122
Rewards Points: 310
I hear ya but unfortunately the architect didn't consider that in his design...
patrickpresti is offline   Reply With Quote
Old 01-31-2016, 07:17 PM   #123
Rewards Points: 1,952
can you sister the joist or hang 3/4 plywood on both sides and drill through. Contact your local buiding department and confirm.
http://www.aconcordcarpenter.com/rei...oor-joist.html
Old 02-01-2016, 04:42 AM   #124
123pugsy's Avatar
They never do......
Old 02-01-2016, 07:26 AM   #125
Rewards Points: 310
My architect told me to do the same thing.
Have you even seen these been used before?
http://www.metwoodstore.com/
Pat
Old 02-01-2016, 07:27 AM   #126
Rewards Points: 310
Ghost,
Attached is the drawing of the first floor bathroom. Let me know what you think...
I also need to pick your brain about the washer/vanity run. With that 3" pipe, I am going to have no choice to drill a hole through a 2x8 floor joists which I know isn't allowed...
I don't know if you saw this last night on page 8 last night...
Pat
Old 02-01-2016, 11:49 AM   #127
123pugsy's Avatar
Pat
Now, that there's some slick looking products.
Old 02-01-2016, 04:24 PM   #128
Rewards Points: 310
Nice right? They have an approved letter from NYS too.
The Following User Says Thank You to patrickpresti For This Useful Post:
123pugsy (02-01-2016)
Old 02-01-2016, 05:28 PM   #129
Your drawings good as long as your vent on the lav is less then 40 foot out.
Old 02-01-2016, 06:35 PM   #130
Rewards Points: 310
Thanks Ghost. The vent will be 30 feet at most...
Old 02-01-2016, 06:36 PM   #131
Rewards Points: 310
You like those joist reinforcers?
Old 02-01-2016, 07:58 PM   #132
Yea but that would be a building department issue not plumbing.
Old 02-01-2016, 08:09 PM   #133
Rewards Points: 310
You're right but it's nice to solve problems with oversized holes going through floor joists...
Old 02-01-2016, 08:22 PM   #134
Rewards Points: 310
Hey Ghost,
Last question, because of routing the 3" drain for the clothes washer may criss cross the 1.5" bath tub drain the way we played everything out, can I run the bath tub drain into the 3" clothes washer drop?
Thanks,
Pat
Old 02-01-2016, 10:05 PM   #135
You would have to vent the tub seperately. It would no longer be on a wet vent.
Why plumbing is a science Ghostmaker Plumbing 9 08-22-2013 08:27 PM
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
