Plumbing Book Reccomendations - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-22-2016, 05:15 PM   #106
WhatRnsdownhill's Avatar
Rewards Points: 2,220
mr ghost..2inch for kitchen sink is code..not an option for better plumbers...
WhatRnsdownhill is offline   Reply With Quote
Old 01-22-2016, 05:40 PM   #107
Rewards Points: 1,860
That's weird I suggest you look up the DFU load for a KS under the IPC then tell me what the actual load 1.5 inch horizontal is allowed to carry. I need the code section. I was a plumber for 28 years my friend. I'm not a noob or handyman like yourself.
Old 01-22-2016, 05:46 PM   #108
Kitchen sink, domestic with food waste grinder and/or dishwasher 2 1
1.5 is the trap size DFU is 2.
TABLE 709.1
DRAINAGE FIXTURE UNITS FOR FIXTURES AND GROUPS
The code section IPC
Your next funny number you will find here
TABLE 710.1(2)
Check out 1.5 inch pipe and total DFU on horizontal branch
It's 3DFU
Do you need the Definition of a horizontal branch also?
So as an inspector of 12 years now I will let you in on a little secret. I inspect exactly by the book. I do not invent code. I read the code and enforce it verbatim. And 1.5 inch for a KS is the minimal code. I would pass that since it meets the code. Other **** inspectors may not but they are enforcing their wishes NOT THE CODE.
Old 01-22-2016, 07:04 PM   #109
TABLE 709.1
TABLE 710.1(2)
It's 3DFU
since you dont know who I am, that comment you can stick somewhere...so were you a licensed plumber for 28 years? and if you dont work in an area its hard for you to state what is or is not code..I wont tell you how to plum in ohio and you can do the same for here..
Old 01-23-2016, 01:29 PM   #110
You also are no help at all on these Forums. NONE!
The IPC Code does not change by state.
I'll even bet you have no license from any state.
Old 01-23-2016, 02:10 PM   #111
Blah Blah Blah....go back to quoting the code book, thats all you seem to know....ill take it from your answer you were never licensed and got some do all inspector job some town needed anyone that could read..
Old 01-27-2016, 04:59 PM   #112
Rewards Points: 310
Hey Ghost,
I'll get those drawings of the first floor bathroom and kitchen to you sooner than later. My plumber should be stopping by within the week to confirm everything. If he doesn't stop by the weekend, I am going to start running the pex supply lines to the second floor.
I will keep you posted.
Pat
patrickpresti is offline   Reply With Quote
Old 01-28-2016, 04:01 PM   #113
Rewards Points: 310
Hey Ghost. Here is the kitchen. I will get the other bath to you tomorrow...
Pat
Old 01-28-2016, 04:25 PM   #114
Rewards Points: 310
Hit the sent button by accident...
Old 01-28-2016, 04:27 PM   #115
Rewards Points: 310
Hit the sent button twice by accident...
Old 01-28-2016, 05:28 PM   #116
KItchens good trap would normally be 1.5 inch unless New York calls.
Old 01-28-2016, 05:36 PM   #117
Rewards Points: 310
I could do 1.5". What would you do?
Old 01-28-2016, 06:33 PM   #118
1.5 inch on the trap and the vent. 2 inch on the drain. Always have a stack clean out if it drops to a basement floor.
Old 01-28-2016, 08:19 PM   #119
Rewards Points: 310
Okay thanks. The stack runs below the floor joists of the first floor. It doesn't run down to the basement floor.
Pat
Old 01-31-2016, 03:01 PM   #120
Rewards Points: 310
Ghost,
Attached is the drawing of the first floor bathroom. Let me know what you think...
I also need to pick your brain about the washer/vanity run. With that 3" pipe, I am going to have no choice to drill a hole through a 2x8 floor joists which I know isn't allowed...
Why plumbing is a science Ghostmaker Plumbing 9 08-22-2013 08:27 PM
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
