Plumbing Book Reccomendations - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2015, 06:10 PM   #16
Rewards Points: 310
Originally Posted by Ghostmaker View Post
Your going to have to make 1 drop for each toilet on the second floor to a first floor wall then to the basement. You will also need a drop from the washer the same way. All these drops need to be 3 inch in diameter. Redraw it that way then we will work on your vents. Pay close attention to the layout of your fixtures on the overview. My Sharpy is dead so my isometric will not scan.
Thanks for the reply. What about the drops for the sinks bathtub and shower? Will they each seperately go feed into the 4" stack?
Thanks,
Pat
patrickpresti is offline   Reply With Quote
Old 11-25-2015, 10:42 PM   #17
Rewards Points: 1,860
Just redo your drawing with the three drops. Make sure you have a way to get them into the basement. Then repost it. Then Ill get the second floor other stuff added.
Easier to describe it to you once I see what you have done. Try to stay out of outside walls.
Old 11-26-2015, 02:08 PM   #18
Rewards Points: 310
Great! I will get the drawing done sometime during the week.
Happy Thanksgiving,
Pat
Old 11-26-2015, 02:32 PM   #19
Rewards Points: 310
Happy Thanksgiving,
Pat
Old 11-26-2015, 05:05 PM   #20
Ok great thanks for hanging in there. Happy turkey day.
Old 11-27-2015, 05:54 AM   #21
Rewards Points: 310
What's the biggest hole that can be drilled in a 2x8 floor joist?
Old 11-27-2015, 07:52 AM   #22
About 2 9/16 " for 2 " and 1.5 " Pipe,thats the bit you need to get. You will also need a saws all to cut your other holes.
A right angle drill will be necessary. You will need a 1 inch bit for your water lines.
Old 11-28-2015, 06:22 AM   #23
Rewards Points: 310
Can a hole big enough be drilled through a 2x8 floor joist for a 3" drain pipe?
Old 11-28-2015, 08:36 AM   #24
You would need to sister that joist with another.
Old 11-28-2015, 03:44 PM   #25
Rewards Points: 310
What about flitch plating the joist with 3/4" plywood on both sides 2' long with glue and screws?
Old 11-28-2015, 04:52 PM   #26
Up to your local building official. I'm not involved in any structural details I only inspect plumbing. Have you figured out a way to get the three second floor drops down?
Old 11-28-2015, 05:27 PM   #27
Rewards Points: 310
I will get that drawing to you of the three drops during the week.
Pat
Old 11-30-2015, 11:37 AM   #28
Rewards Points: 310
Here are the full plan layouts of the first and second floors...
Plumbing Book Reccomendations-firstfloorplan.jpg   Plumbing Book Reccomendations-secondfloorplan.jpg
Old 11-30-2015, 11:46 AM   #29
Rewards Points: 310
Here is what I have for the (3) 3" drops. I'm going to have to go through floor/ceiling joist to get to the first floor walls. there is no way around it. let me know what you think...
I'm also thinking about flipping the bathtub upstairs so I can get it closer to the washer and that one vanity in the other bathroom.
Thanks,
Pat
Plumbing Book Reccomendations-secondfloorplumbingplanupdate.jpg   Plumbing Book Reccomendations-firstfloorplumbingupdate.png
Old 11-30-2015, 11:50 AM   #30
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Thanks,
Pat
I agree with the tub flip.
I would be a pain to reach in and turn on the water with the vanity where it is.
123pugsy is offline   Reply With Quote
Why plumbing is a science Ghostmaker Plumbing 9 08-22-2013 08:27 PM
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
