Plumbing Book Reccomendations - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2016, 10:31 AM   #166
Rewards Points: 310
I'm sorry to hear it didn't work out for you. All situations are different.
patrickpresti is offline   Reply With Quote
Old 02-04-2016, 10:38 AM   #167
WhatRnsdownhill's Avatar
Rewards Points: 2,220
true, I dont know your experience putting together fittings or laying out a system..do you have right angle drill and bits to drill beams and then to set the fittings with proper angles and swings and what combo of fittings to get certain hookups done?..
WhatRnsdownhill is offline   Reply With Quote
Old 02-04-2016, 10:42 AM   #168
Rewards Points: 310
Yes, I feel pretty confident with that end of things...
Old 02-04-2016, 12:03 PM   #169
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,682
Originally Posted by patrickpresti View Post
Pugsy,
Good morning. Thanks for the response...The second floor lavs already are vented. I thought S traps are not legal anymore?
Pat
They're not.
The lav on the 2nd floor RHS shows an S trap on your drawing.
123pugsy is online now   Reply With Quote
Old 02-04-2016, 12:07 PM   #170
123pugsy's Avatar
This is the part that most DIY's have a hard time with.
I had a plumber friend to ask questions about which fittings to use. I then looked up the info for the "why" they were used as he said, to thoroughly understand it.
Old 02-04-2016, 04:19 PM   #171
Rewards Points: 1,862
Originally Posted by 123pugsy View Post
How about the S trap on the 2nd floor lav?
San T and vent straight up?
Your correct pugsy I missed that You stack the tees a 3 by 2 to the washer and a 1.5 san teee to the lav at stub out height. No turning up for the lav.
Old 02-04-2016, 04:21 PM   #172
just for reference here is an expired islip license, it doesnt pay to keep active licenses in all the towns and villages,cost too much unless I have active work there, most reciprocate to where you took your test..when I do work, I dont let the homeowner get involved in the piping ,just the way I and most licensed plumbers are, im in business to make money, not teach plumbing class, nothing personal here, the same goes for friends or relatives..
I'm the same way if I was the plumber then I would install the pipe.
Old 02-04-2016, 04:29 PM   #173
Rewards Points: 310
Ghost,
Sorry that the overall diagram isn't showing the proper fittings. I was only showing the detail of the pipe sizes. Not the exact locations and type of fittings.
Old 02-04-2016, 06:15 PM   #174
Rewards Points: 310
Do you have any recommendations for any plumbers?
Why plumbing is a science Ghostmaker Plumbing 9 08-22-2013 08:27 PM
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
