Plumbing Book Reccomendations - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2016, 08:04 AM   #151
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Originally Posted by patrickpresti View Post
Islip said they follow NYS code. There is no local codes they follow...
ny code is a combination of codes not the IPC word for word...$80 and you can buy the NYS Plumbing code book and study up..
WhatRnsdownhill is offline   Reply With Quote
Old 02-04-2016, 08:05 AM   #152
So you're saying the dry vent for the wet vent should be 2" instead of 1 1/2"?
all wet vents are usually a pipe size bigger as specified in the section and chart..
Old 02-04-2016, 08:06 AM   #153
New York State Plumbing Code 2010 Edition | Construction Book Express
Plumbing Code of New York State, 2010 Edition is a fully integrated custom code based on the 2006 International Plumbing Code.
based on, not word for word...notice the wording....custom code BASED on...
maybe you can get a copy for mr ghost so hes not talking out his a$$....
Old 02-04-2016, 08:35 AM   #154
Rewards Points: 310
Originally Posted by ShtRnsdownhill View Post
table 909.3 you should read ,first # is pipe size second # is fixture load
Thanks for the chart reference. It looks like since a water closet is 3 DFU's, I will need to use a 2" pipe for the dry vent...
patrickpresti is offline   Reply With Quote
Old 02-04-2016, 08:46 AM   #155
you can wet vent if you can meet proper venting for the dfus
but here is the question I have for you, no sarcasm intended....where is the licensed plumber that is going to either pipe or cover you on this job? he should know all this code and advise you, his butt is on the line..?
Old 02-04-2016, 08:52 AM   #156
Rewards Points: 310
Saturday he is stopping by
Old 02-04-2016, 09:01 AM   #157
ok, then show him what you have and he will fill in the blanks..but some out of state person that has no clue about our NY state code, is hard to listen to telling you how to meet our code...
Old 02-04-2016, 09:13 AM   #158
Rewards Points: 310
Would you be interested in doing the work for me?
Old 02-04-2016, 09:34 AM   #159
thought you had a plumber lined up?
Old 02-04-2016, 09:38 AM   #160
Rewards Points: 310
I do but it can't hurt to get a second opinion...
Old 02-04-2016, 09:47 AM   #161
just for reference here is an expired islip license, it doesnt pay to keep active licenses in all the towns and villages,cost too much unless I have active work there, most reciprocate to where you took your test..when I do work, I dont let the homeowner get involved in the piping ,just the way I and most licensed plumbers are, im in business to make money, not teach plumbing class, nothing personal here, the same goes for friends or relatives..
Old 02-04-2016, 10:05 AM   #162
Rewards Points: 310
Understood. Figure I would ask.
Old 02-04-2016, 10:06 AM   #163
Rewards Points: 310
The plumber is obviously going to get paid for all of the work he does...
Old 02-04-2016, 10:17 AM   #164
I understand that, but its double the time to keep track of someone that needs pointers how to pipe, and if im doing that I cant be doing my own work on the job, now if you want to pay for teaching time, but it sounds you are trying to cut costs by doing some of the work yourself, so in the end, no money would really be saved...
Old 02-04-2016, 10:19 AM   #165
Long ago in the past I did what you are trying to do with a friend/customer and it turned into a nightmare for many reasons, and alot of wasted pipe , fittings ,time and lots of hurt feelings and aggravation..never again...lesson learned..
Why plumbing is a science Ghostmaker Plumbing 9 08-22-2013 08:27 PM
Frame or plumbing first? RichTibo Plumbing 1 07-26-2013 11:55 AM
Plumbing help! firsttimeremode Plumbing 45 10-05-2012 10:38 AM
Shoring and Video plumbing inspection. Is it worth it? Geaux4Tigers Plumbing 22 12-12-2010 02:48 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 03:04 PM
