Plumbing Below Concrete Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2015, 12:59 PM   #1
Rewards Points: 6
Hi all,
I'm trying to add a bathroom above an existing concrete slab. I was going to cut into the concrete to create a trench to put the plumbing into.
My question is, is there a certain depth below the surface of the slab that the drainage pipes need to be below? Or can I put the pipes basically right below the surface of the slab as long as I have the proper slope?
Any help would be much appreciated...thanks!!
chrisinseattle is offline   Reply With Quote
Old 08-11-2015, 06:03 PM   #2
Rewards Points: 1,938
Normally the depth would be determined by the pipe you would be tying into to drain. So perhaps you should start there.
Moving Plumbing in Concrete Slab Ceiling markamusante Building & Construction 3 05-09-2013 06:42 PM
How to frame, install plumbing and shower over a concrete slab nflravens Building & Construction 0 11-13-2011 10:00 PM
Relocating plumbing - concrete slab foundation vsheetz Building & Construction 17 04-23-2011 05:22 AM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
