Plumbing Addition- Vent Questions/kindergarden Drawings - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 09-18-2017, 07:18 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 258
Re: Plumbing addition- vent questions/kindergarden drawings
Originally Posted by Onlyincali View Post
Thanks for the replies. The sink upstairs is a laundry sink that will rarely get used except for washing the pets/shoes. The sink below is a true kitchen sink that will be used frequently.
The amount of usage does not matter, next year you may not live there and the person who does might run a laundry mat
edit- Also, can't I tie the drain pipe from the second floor into the bottom floor drain, providing its after the trap/vent. It wouldn't even be considered wet venting of the downstairs sink, providing its below the vent/trap, right? A 2" pipe should be able to manage the Washing machine from above per code, right? I think a 2" can hold a 20-24 fixture load, so no issue there?
See my attached drawing. While you are pretty much correct on the vertical pipe load- as soon as it turns horizontal under the floor you have to reduce the load to 8 DFU's. You are maxed out with the 3 fixtures shown. In fact, you might be over loaded depending on Cal sizes. You need to dump that into a 3" bldg. drain
Plumbing addition- vent questions/kindergarden drawings-2story-sink.png
The Following User Says Thank You to TheEplumber For This Useful Post:
Onlyincali (09-20-2017)
Old 09-19-2017, 12:01 PM   #17
Rewards Points: 26
Thank you thank you thank you!
Onlyincali is offline   Reply With Quote
Old 09-19-2017, 12:05 PM   #18
Rewards Points: 26
oops, you mention turning into a 3" Would you turn into 3" where the two 2" meet on the first floor and then bring 3" into the ground and to the main sewage line? Or bring both 2" pipes through into the ground and connect at a wye into a 3" and then run that 3" (roughly 15ft) to the main 4" drain?
Old 09-19-2017, 12:49 PM   #19
Plumber
Rewards Points: 258
The horizontal lines needs to be 3" based on your load.
Personally, i'd put a 3x2x2 y above the floor.
Sent from my XT1650 using Tapatalk
is this vent needed and hows the plumbing? charles3526 Plumbing 10 10-11-2016 06:05 PM
Plumbing Vent In Basement Laundry Room tjfslaughter Plumbing 7 05-15-2013 10:42 AM
plumbing vent through side wall basan Plumbing 6 03-24-2012 02:00 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Addition Vent question MarcoFL Plumbing 4 08-14-2009 10:19 PM
