Plumber's Putty For Sink Drain Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2015, 07:06 PM   #1
Rewards Points: 32
Plumber's Putty for Sink Drain Leak?
I hope this is easy: The sink in our bathroom will not hold a basin of water when the stop is closed. I thought it was the stopper itself, but when brushing my teeth, I watched as the suds went into the gap between the sink and the drain lip instead of straight down the drain. Strangely, there is nothing leaking under the sink. Not sure where the water is going. Underneath there is a large nut holding the drainpipe tight to the basin and between that and the sink is a rubber o-ring. I'm hoping a dab of plumber's putty under the drain flange will do, but not sure. Any better ideas? Thanks!
sonofbuster is offline   Reply With Quote
Old 09-07-2015, 07:13 PM   #2
Bill Kearney
Rewards Points: 1,174
Many sinks have are a 'bowl within a bowl'. If there's an overflow hole near the top of the sink bowl then that likely runs to a 'collar' of sorts that the drain tail piece goes through before making it's connection to the trap. The water leaking around the lip is going to the same place the overflow would. The simple fix would indeed be to remove the drain assembly, clean the surfaces thoroughly and use a new bead of plumbers putty in-between it and the sink bowl. Squeeze it tight enough to force out most of the putty, clear away the excess and you're done.
-- Bill
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
sonofbuster (09-07-2015)
Old 09-07-2015, 07:55 PM   #3
Rewards Points: 32
Thanks! Your explanation makes sense. Gonna give it a go now.
Old 09-07-2015, 08:47 PM   #4
Rewards Points: 32
Jeez, it's been a while...
Meanwhile, the collar is stuck to the drain pipe so I have it soaking in PB Blaster.
Plumber's Putty for Sink Drain Leak?-img_20150907_212236_1441676664613.jpg   Plumber's Putty for Sink Drain Leak?-img_20150907_212247_1441676694370.jpg   Plumber's Putty for Sink Drain Leak?-img_20150907_212406_1441676709893.jpg
Oatey plumbers putty on pvc boilermaker27 Plumbing 10 02-08-2014 11:02 PM
New faucet & pop up drain - Minor leak westbank Plumbing 11 09-30-2013 09:27 AM
Plumbers putty or puttyless washer? kcrossley2 Plumbing 2 10-07-2012 12:58 PM
Plumbers Putty on Plastic index1489 Plumbing 0 03-19-2012 11:37 AM
Leak under tub at joint to drain iliketowork Plumbing 4 12-10-2011 07:15 PM
