Is Plumber's Putty Necessary - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree7Likes
  • 3 Post By rjniles
  • 2 Post By MTN REMODEL LLC
  • 1 Post By Oso954
  • 1 Post By snic
Old 11-21-2019, 02:51 PM   #1
Rewards Points: 737
Is Plumber's Putty necessary
Installing a brand new toilet on to a brand new floor. I have done a dry test fit to insure things would go without a hitch. The toilet appears to be sitting down on the floor without any rocking or gaps between the toilet base & the floor, without tightening the flange bolts.
There is a instruction to apply a 1 inch bead of Plumber's Putty all around the toilet's base prior to setting the toilet to prevent any rocking, which I do not detect in the dry fit. Is the Putty necessary? I'm asking because should I have a leak, wouldn't the Putty prevent me from seeing the leak since I assume the Putty would hold water under the toilet. This could ruin the flooring & cause rot issues if undetected. I've looked at the other toilet's in my house & see no Putty around them & they all sit tight & level to the finished floor. Thank you for your advice & opinion. It's appreciated. Plumbing drive's me nuts.
maddog1 is offline   Reply With Quote
Old 11-21-2019, 03:21 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 196
Re: Is Plumber's Putty necessary
I have never heard of using plumbers putty under a toilet. What good would it do, it is soft and would just squish out?
I caulk around a the base of a toilet with silicone leaving a gap at the rear as a place for leakage to seep out if a problem.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-21-2019, 03:28 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
^^^^^^^^^^^^^^^^^^^RJNILES >>>100%^^^^^^^^^^^^^^^^
Just curious...where the heck did those instructions come from...?????
Bondo and Oso954 like this.
MTN REMODEL LLC is offline   Reply With Quote
Old 11-21-2019, 03:55 PM   #4
Oso954's Avatar
Rewards Points: 674
I agree with RJ & Mtn.
You caulk around a toilet to keep spilled water or a wet mop from letting water run under or get pushed under the toilet. You leave a small gap to let a leak from inside run out.
If your toilet rocks due to an uneven floor, you can buy plastic toilet shims to shim up the low area(s).
rjniles likes this.
Oso954 is online now   Reply With Quote
Old 11-22-2019, 10:23 AM   #5
Rewards Points: 737
The use of putty was on the packages of two wax seals I bought. The toilet mfg never mentions the use of putty.
Agree with what was said here. Putty is not necessary.
Old 11-22-2019, 10:55 AM   #6
Rav
Rewards Points: 864
I just finished installing a new wax ring on an existing toilet. It's instructions also said to put a putty ring around the outside rim (which I did not do). Picture attached (boxes around text added by me).
Rav is offline   Reply With Quote
The Following User Says Thank You to Rav For This Useful Post:
maddog1 (11-24-2019)
Old 11-22-2019, 11:16 AM   #7
Oso954's Avatar
Rewards Points: 674
Look at the lower left corner, an Oatey affiliate.
Guess who makes Sta Put putty.
I've never used that particular putty/sealant. But if it takes anywhere near as long to roll as regular plumbers putty, I think I'll stick to caulking.
I don't use wax seals anymore. I went to the Fernco wax free toilet seal close to 20 years ago, haven't used a wax ring since.
Old 11-23-2019, 12:58 PM   #8
Rewards Points: 178
With some toilets I've installed, no matter how carefully I shim it and tighten the bolts, it's just not stable without some caulk. It might have to do with how even the floor is. If it's a bit warped, the toilet is just not going to be very stable. By the way, I try to avoid silicone caulk under toilets because it's hard to remove when you replace the toilet. Latex is fine for this purpose.
To answer the OP's question about being able to detect a leak: yes, that's a potential issue. But look at it this way: if your toilet moves around a little every time someone sits on it, you're almost certain to develop a leak. If it's stable and the wax ring is installed right, it won't leak. So the here's the trick: install the toilet, and if it's stubborn and refuses to be stable, caulk around it AFTER flushing it a few times to make sure there's no leak. If you're really worried about seeing a leak, don't caulk all the way around - just do the front and part of the sides. Or maybe one side is by a wall and can't be seen; don't caulk that side. And definitely don't caulk the back.
As for putty: HAHAHAHAHAHA! I'd only use it if what they're hawking hardens up (unlike regular plumber's putty), and is cheaper than the cheapest possible latex caulk, AND I don't already have a half-used tube of caulk lying around (which is almost never).
snic is online now   Reply With Quote
The Following User Says Thank You to snic For This Useful Post:
Old 11-23-2019, 01:54 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 196
Latex caulk gets dirty and discolors. Silicone is easily cleaned off the floor with a single edge razor blade.
The Following User Says Thank You to rjniles For This Useful Post:
Old 11-24-2019, 09:47 AM   #10
Big Dog
Drachenfire's Avatar
Rewards Points: 4,286
Oso954 hit it in the head. It is nothing but a marketing ploy. This is reinforced by the fact that they specify the brand to use.
If there is any rocking, you need nothing more than shims sold for the purpose and a bead of silicone caulk.
My Deck Rebuild Progress
Fate whispers to the warrior, "You cannot withstand the storm," and the warrior whispers back, "I am the storm."
Drachenfire is offline   Reply With Quote
Old 11-25-2019, 10:34 AM   #11
Rewards Points: 178
Or pennies. They're $0.48 cheaper .
ktownskier likes this.
Old 11-25-2019, 11:04 AM   #12
Rewards Points: 844
I am dumbfounded that they want an inch of that putty around the edge. But then again, it is another one of their products. The more you use, the more you buy.
I would never put an inch of caulk around the edge. My floor would never be that far out of level.
The only stupid question is the one you DON'T ask!
ktownskier is online now   Reply With Quote
