Plastic DWV Piping Heads Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-08-2015, 05:57 PM   #1
Rewards Points: 1,938
Plastic DWV Piping heads up
Both PVC and ABS manufacturers of plastic DWV piping are now considering voiding warranties if the pipe is subject to an air test. Be advised that your local plumbing codes may start switching to water test only and a 10 foot head at a time. We in Ohio haven't figured out what to do about winter yet.
Also be advised that SCD 40 ABS and PVC manufactures have already warned the various water heater and furnace companies that their pipe is not to be used as a heat exhaust. They have made new pipe for that that is much more melt resistant. Thermo plastic.
Link Below
o and including 65C
System 636 CPVC is rated for flue gashttp://www.google.com/url?sa=t&rct=j...95039771,d.b2w
temperatures up to and including 90C
The Following 3 Users Say Thank You to Ghostmaker For This Useful Post:
oh'mike (06-08-2015), TheEplumber (06-08-2015), tylernt (06-09-2015)
Old 06-08-2015, 09:55 PM   #2
Rewards Points: 2,636
"Also be advised that SCD 40 ABS and PVC manufactures have already warned the various water heater and furnace companies that their pipe is not to be used as a heat exhaust. They have made new pipe for that that is much more melt resistant. Thermo plastic. "
Does that mean all homes with existing PVC or ABS vent piping should retrofit to the new?
bob22 is offline   Reply With Quote
Old 06-09-2015, 06:36 PM   #3
What it all means is if for some reason melts through you the installer get to be part of the lawsuit. On the receiving end. It means they are covering their collective butts.
Old 06-09-2015, 06:57 PM   #4
I would suggest some reading from this site.
http://www.chimneysavers.com/Chimney..._with_PVC.html
Remember in the end you decision may cost someone their life.
Old 06-09-2015, 07:01 PM   #5
Plumbing Engineer site.
http://www.plumbingengineer.com/cont...e-pipe-failure
The Following User Says Thank You to Ghostmaker For This Useful Post:
Yodaman (06-09-2015)
Old 06-09-2015, 07:05 PM   #6
Super Moderator
joed's Avatar
Rewards Points: 31,946
It means they can add another product to their line of pipes and charge more for it.
Old 06-09-2015, 07:10 PM   #7
I suggest you read the engineer report.
Capping off 75% of sprinkler heads? Re-planning sprinkler system? denemante Landscaping & Lawn Care 3 11-12-2014 12:11 AM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Plastic 4mil under interior walls? Avadon Carpentry 4 05-03-2011 06:36 PM
sealtite not plastic underground? walt1122 Electrical 6 04-14-2011 03:39 AM
Plastic instead of metal... hvaclover Electrical 11 11-13-2008 09:07 AM
