Pipe To Septic - Slow Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2015, 09:25 PM   #1
Rewards Points: 12
Pipe to septic - slow leak
Hello - just noticed the main PVC pipe running out to my septic tank is leaking slowly...one small drip every 30 seconds or so. This is in the basement right before the wall.
PVC is new, I think, installed this summer by a plumber.
There is a square plug(?) on the end that I can twist with a wrench. As I twist either direction, the leak gets stronger. I haven't twisted too far, fearing I'd get covered in you-know-what!
Any thoughts? Could pipe to septic be frozen up? This has been a cold MN winter with zero snow ground cover, and my well froze last week, too, so just thinking...
See attached photo of the end of the pipe. Water is leaking at the circle line below the square.
neatonfarm is offline   Reply With Quote
Old 03-03-2015, 09:40 PM   #2
Rewards Points: 3,432
Is everything draining ok? Nothing backing up? The cleanout plug may have a little condensation going on there. Drip looks like clear water. If everything is draining, I wouldn't worry too much about it.
Others will be along with more advice/suggestions.
jmon is online now   Reply With Quote
Old 03-03-2015, 09:52 PM   #3
Plumber
TheEplumber's Avatar
Welcome to the forum!
You may be frozen- depends on the pipe depth
Or your septic tank line or the tank itself may have a back up issue.
Or hopefully- just a loose plug.
If its frozen there is a good chance your plumbing fixtures will back up soon.
Same for a tank issue.
Try to tighten the plug some more- but not too tight or you will crack the female threads causing it to leak more.
There is a way to see if there is much water behind the plug- set a trash can under the plug. Then drill a 1/4" hole near the bottom of the plug. This will tell you if there is water If a steady stream comes out, drape a rag over the drill hole and allow it to drip into the can.
You can buy a replacement plug at the hardware store for a couple bucks. Use pipe dope on the treads to seal it. (which the installer didn't do)
Old 03-05-2015, 04:25 PM   #4
Rewards Points: 12
Thanks for the help, guys. I tightened 'er up and it quit.
The Following User Says Thank You to neatonfarm For This Useful Post:
jmon (03-05-2015)
Drain pipe leak, quick fix? Ultrarunner2017 Plumbing 15 02-15-2012 08:57 AM
Water Pipe Leak in Backyard diginside Plumbing 2 07-08-2010 04:50 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Type of pipe for main stack to septic tank GD73 Plumbing 2 08-28-2009 10:17 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
