Pipe Fell Down Well-- Help Me Get It Out? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 02-15-2017, 03:36 PM   #31
Rewards Points: 6
Re: Pipe fell down well-- Help me get it out?
Yeah that is what i want to know ... if you got it working. I saw that you abanded the pipe, but did not know if you ran into any other issues by leaving the pipe down there.
Thanks for the reply... i kinda have the same issue, so i am going to give it a shot this weekend..
Pontgta is offline   Reply With Quote
Old 02-27-2017, 09:11 AM   #32
Rewards Points: 6
So,
I have an updtate to my issue, since last i psoted . I had similar issue, 2 inch pvc casing, 1 inch drop pipe with a packer at the bottom of this well. I did Know thta the well was only 50ft deep total, and i also knew that there was a coupler at the end, but was in water. Went to lowes and tried a coulpe of things to see what would fit. I was actually able to retrieve the pipe and packer from the well by using a 1 inch threaded galvanized pipe atached to 60ft of pvc pipe. I pushed the pipe down and felt it go into the coupler and turned the the pipe ,so it would kinda thread to the coupling. Well it worked
I know this was not my thread, but i got some great ideas from it, and like to post successful ends to prooblems.
Again thanks for all your help. Oh and the pump is now working excellent as well..
Old 02-27-2017, 12:40 PM   #33
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,854
A water well driller will have an overshot retriever..... has slips on it...
Maybe one will rent it to you.
Dave Sal and de-nagorg like this.
MTN REMODEL LLC is offline   Reply With Quote
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
PVC pipe broken on Gas Furnace/AC unit Keyo77 HVAC 8 10-16-2007 03:08 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
