Pinhole Leak Copper Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2016, 10:20 AM   #1
Rewards Points: 512
I've had this for a while but haven't done anything about it, as I address other issues and, honestly, forgot about it. My attention was drawn to it today. May be getting slightly worse:
I have installed shark bite shut offs in some other spots in the basement but, overall, am a novice with pipes.
For this particular section, would I be able to use compression/shark bite style add ons?
https://drive.google.com/file/d/0B5y...ew?usp=sharing
Thanks for your help!
Joe
joetab24 is offline   Reply With Quote
Old 06-28-2016, 03:46 PM   #2
Rewards Points: 3,206
Re: Pinhole Leak Copper Water Pipe
If you dont have soldering skills or just dont like it, sharkbytes make it a very simple fix Joe. I have some over six years old and still no leaks.
If you go the sharkbyte route; I would get sharkbyte tee, couple sharkbyte couplings, and some extra pipe to make the repair. You can always bring back what you dont need.
jmon is offline   Reply With Quote
Hotwater tank water leak and no hot water bayin Plumbing 12 09-17-2015 04:09 PM
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Turning off hot water to fix 1/2 inch CPVC pipe in crawl space steve3847 Plumbing 21 12-20-2012 01:53 AM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
