Pin Hole - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree5Likes
Old 06-09-2019, 03:45 PM   #16
Rewards Points: 214
Re: pin hole
Can i use a slip coupler for that being so close to the rafter knock out or should I just cut on the other side of the rafter?
bluefish7 is offline   Reply With Quote
Old 06-10-2019, 07:58 AM   #17
Rewards Points: 1,347
Re: pin hole
This would be my easy button here:
huesmann is offline   Reply With Quote
Old 06-10-2019, 01:01 PM   #18
Contractor/Engineer
Rewards Points: 1,078
Re: pin hole
Cut as convenient a few inches to either side of the hole. (The further the better so you can bend the PEX you'll be using.)
Install pex with sharkbite to replace the removed section.
No soldering required. No problem bending copper trying to get the coupling onto both ends (you'd want the solder coupling that does NOT have the dimple - you want the kind that can completely slide onto one side, then you align by sliding back over the hole and solder - if you enjoy soldering)
Domo is offline   Reply With Quote
Old 06-10-2019, 01:07 PM   #19
Contractor/Engineer
Re: pin hole
You want the one without the dimple for an in-line patch.
Or you can use the "snugger" type which slips, as required as shown; (I actually don't like these as the original copper has to be in very good condition and I'm paranoid the repair coupling might migrate...since only some O ring is holding it - I like sharkbite that has teeth to hold affixed)
Old 06-11-2019, 08:14 AM   #20
Re: pin hole
Oh you're right about the dimple—I just saw the inline fitting and went with it.
I cut a 3/4" hole 85% of the way vertically down into 2 5/8" wide joist in basement!! HTFreak Building & Construction 6 09-10-2017 11:50 AM
6" Hole in Brick Wall BusyPete Concrete, Stone & Masonry 11 08-15-2016 09:30 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 11:55 AM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 06:55 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
