Picking A Toilet? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2016, 10:41 AM   #1
Rewards Points: 302
Picking a toilet?
Anybody have any recommendations when it comes to toilets?
I'm on the fence between an American Standard and a Toto...
gizzygone is online now   Reply With Quote
Old 02-04-2016, 11:03 AM   #2
WhatRnsdownhill's Avatar
Rewards Points: 2,220
Toto makes some nice stuff...try and stay away from the big box stores, there is a difference on the internals...
WhatRnsdownhill is offline   Reply With Quote
The Following User Says Thank You to WhatRnsdownhill For This Useful Post:
gizzygone (02-04-2016)
Old 02-04-2016, 11:14 AM   #3
Rewards Points: 302
I heard Toto was one of the best; but I also heard parts are fairly proprietary? Will it be difficult finding parts if I need them?
Old 02-04-2016, 11:33 AM   #4
Rewards Points: 127
I own two toto's and as much as you like a toilet, I like them both. They flush well, are frugal with water and easy to clean. As for parts, maybe not a big box store, but plumbing supply houses should have them. As for the needs for parts, my oldest is 10 years old and it has never need a part. Unlike my standard toilets where the guts would need to get replaced every three years or so.
jimn01 is offline   Reply With Quote
The Following User Says Thank You to jimn01 For This Useful Post:
WhatRnsdownhill (02-04-2016)
Old 02-04-2016, 11:55 AM   #5
Rewards Points: 302
Sounds good. I'm leaning towards the drake 2, 1.28gpf, although I see there's a 1.0gpf model as well...
Old 02-04-2016, 01:57 PM   #6
all these low flush toilets make the drain cleaners a ton of money, as the plumbing systems were not designed for such low water carrying the waste all the way out to the street and end up over time causing build up in the sewer main and then stoppages....all in the name of saving some water and sewage processing expense for the municipality...
Old 02-04-2016, 02:06 PM   #7
Rewards Points: 302
Sounds like 1.28 is the way to go! Haha.
Old 02-04-2016, 02:23 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 884
Personally I would go to Habitat, buy a decent looking toilet, pressures wash, install a new fill and flush valve, trip lever and bowl to tank bolts. Will look like new.
If you insist on new, get a 1.6 gallon not a 1.28.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 02-04-2016, 03:14 PM   #9
Oso954's Avatar
Rewards Points: 1,832
I have 2 of the Toto Drakes, a 1.6 and a 1.28 gpf. Both are superior toilets. I prefer the 1.28gpf because of the cyclone flush/wash and the Sanagloss finish.
Oso954 is offline   Reply With Quote
Old 02-04-2016, 03:33 PM   #10
Rewards Points: 582
kohler cimarron comfort height....
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (02-04-2016)
Old 02-04-2016, 04:16 PM   #11
Retired Moderator
Rewards Points: 7,174
Todo flappers are available at the big box stores.
Old 02-04-2016, 06:31 PM   #12
Rewards Points: 302
Good to know.
I'll have to look into the Kohler as well. Although, kids are in planning: is a comfort height an issue?
Old 02-04-2016, 06:34 PM   #13
Rewards Points: 582
Good to know.
comfort height easy on our old knees
Old 02-04-2016, 07:04 PM   #14
Retired Moderator
I have installed over a hundred toilets in the last few years----all were the tall ones except for one----people are taller now than when toilets were invented.
I don't know if little kids have a hard time with the taller stools----never thought about it---
Old 02-05-2016, 03:06 PM   #15
Oso954's Avatar
There are various steps, platforms, ladders available. Little people need them whether regular height or comfort height, unless you want to help them.
https://www.google.com/search?q=toil...UICSgD#imgrc=_
Toilet location has become a bit of a problem BOUTYM Plumbing 13 10-10-2011 11:19 AM
Where to Move this Toilet? estburke Plumbing 8 10-10-2010 11:52 PM
Leaky toilet drain secutanudu Plumbing 0 08-17-2009 10:14 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
