Pex Uponor Options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2017, 09:19 PM   #1
Rewards Points: 76
Pex Uponor options?
Want to add a cold water faucet in the basement and the plumbing is Pex Uponor that the plumber installed with an expansion tool. What are my options if I want to add a Tee into the 3/4" line and then run 1/2" down to my new faucet? I have all the tools to work with regular PEX and the crimp rings. But never dealt with the expansion type rings and fittings. Is there a way to add a Tee into the line without an expensive tool? Then I can just use regular PEX tubing/fittings/crimp rings if I can adapt from the expansion to crimp style. Not a huge fan of sharkbite fittings but can they be used for going from expansion to regular style pex?
ponch37300 is offline   Reply With Quote
Old 03-09-2017, 12:55 AM   #2
Rewards Points: 38
Re: Pex Uponor options?
You can use regular crimp ring or Sharkbite fittings with Uponer PEX. Use the crimp rings...
SHR Plumber is offline   Reply With Quote
Old 03-09-2017, 06:14 AM   #3
Civil Engineer
Rewards Points: 5,246
Uponor PEX is Type A PEX. Any crimp ring system compatible with Type A PEX should work fine. As a point of reference, the dimensions for Type A, Type B and Type C PEX are standardized, however Type A is more flexible, so it works with the expansion rings Uponor uses.
Old 03-09-2017, 06:50 AM   #4
Rewards Points: 76
That's good to hear that I can use crimp rings with it. Thanks.
