Pex And Spray Foam - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2015, 06:04 PM   #1
Rewards Points: 442
Pex and spray foam
I was told by the county plumbing inspector that pex might get damaged with some kinds of spray foam. Something in it eats away at the pex.. Is Great Stuff Gaps and Cracks ok to use with Wirsbo Pro-Pex (expansion)?
Thanks,
Jeff
zootjeff is offline   Reply With Quote
Old 11-25-2015, 06:49 PM   #2
Rewards Points: 18,794
He does not have a clue, Great stuff foam has no effect on it.
Very little effects PEX.
Old 11-25-2015, 07:48 PM   #3
Rewards Points: 290
Interesting: I'd like to hear some input as well...
gizzygone is offline   Reply With Quote
Old 11-25-2015, 10:39 PM   #4
Rewards Points: 1,860
Plumbing pipes, now using PEX (cross-linkedpolyethylene) more frequently
Uponor (Iargest manufactuer of in-floor radiant heat tubing) has
a position memo
No chemical breakdown of their material
Using spray foams.
