Pex To Sharkbite To Galvanized? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2016, 03:38 PM   #1
Rewards Points: 294
Pex to sharkbite to galvanized?
Can pex be fitted to galvanized pipe via a straight sharkbite coupling?
Mikeron is offline   Reply With Quote
Old 02-22-2016, 03:54 PM   #2
Rewards Points: 18,988
Simple answer, no.
Main reason is brass in direct contact with steel will corrode.
One way around it if you you used a galvinzed coupling, dielectric nipple then a FPT to Pex fitting.
Should be getting rid of every inch of galvinized you can. It's all going to leak at some point and close up on the inside.
Mikeron (02-24-2016)
Old 02-22-2016, 05:04 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 278
Sharkbites are not sized for galvanized pipe. The diameters are different. You need threads.
Brass is generally accepted to connect to galvanized pipe as dialects unions cannot be concealed
The Following User Says Thank You to TheEplumber For This Useful Post:
JERRYMAC (02-22-2016)
Old 02-22-2016, 07:16 PM   #4
Rewards Points: 582
did you get the answer you were looking for...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 02-24-2016, 10:51 AM   #5
Rewards Points: 102
There will be a very small galvanic current which will very slowly cause the galvanized pipe to corrode. Shark bites do come in threaded applications so that pex can be joined to galvy. Knowing the risks, I would have very little concern about doing this and would expect it to last years.
Tally Wacher is offline   Reply With Quote
The Following User Says Thank You to Tally Wacher For This Useful Post:
Old 02-24-2016, 01:33 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
You need a threaded end on the galvy for that application.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 02-24-2016, 02:57 PM   #7
Rewards Points: 582
best to get rid of the galvanized pipe...
Old 02-26-2016, 12:54 AM   #8
Rewards Points: 102
It is a given, you will need to rent a threader.
Replacing Some Galvanized Pipe epsilono Plumbing 6 12-03-2015 07:53 AM
Sharkbite Fittings davidblackwoods Plumbing 55 06-14-2013 08:14 PM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Sprinkler: Splice PVC onto older NONthreaded Galvanized? kronic24601 Landscaping & Lawn Care 0 02-13-2011 03:18 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
