PEX Problems? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2016, 07:54 AM   #1
Rewards Points: 1,274
PEX problems?
The attached photo is from the post one or two down titled White Crush on PEX. So far I've only read good things about pex but this is a good post on what can happen.
Now I'm worried about the tubes that get buried in the walls. If it is a slow leak, why the leak?
Is it the kind of crimping used here? Probably improper tool or pressure used? Incomplete crimping? Is it living with it as long as inspection is passed? So far, self soldered copper joints were reliable. Neither a call back nor finding a leak in my house. Is it about the same with pex?
Thank you in advance.
carpdad is offline   Reply With Quote
Mac Problems l008com PC Repairs & Upgrades 4 06-25-2016 09:17 AM
Power problems on second floor, first floor is fine rarken1 Electrical 21 05-16-2015 11:42 AM
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 06:42 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
