PEX Or Poly For Tank-to-House Water Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joed
Old 09-30-2016, 03:32 PM   #1
Rewards Points: 44
PEX or Poly for Tank-to-House Water Pipe?
I'm running a new 100' water line (chlorinated - not drinking water) from a water tank to the house (it's rural - no mains). It's the SW desert, average low - 40F, and rarely hits freezing. There already exists a leaky 2.5" internal diameter PVC pipe burried in the ground, through which I plan to feed the new line. It's a small house and either the shower runs, a sink, or the toilet refills - so usually only one outlet at a time is running. I have a small pressure feed pump in place at the house end, with 3/4" connections, and the water pressure is fine. I was told 3/4" will do the job well enough. Is NSF poly pipe any good? Poly is much cheaper than Pex. I will of course need to fit threaded end terminals.
Anything else to consider?
Suggestions appreciated. Thanks.
Frank_Drebin is offline   Reply With Quote
Old 09-30-2016, 03:50 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,972
Re: PEX or Poly for Tank-to-House Water Pipe?
Black poly is fine for water line to a pump. It used here all the time with no issues as feeder water lines.
lenaitch likes this.
The Following User Says Thank You to joed For This Useful Post:
Frank_Drebin (09-30-2016)
Old 09-30-2016, 03:53 PM   #3
Rewards Points: 44
Thanks!
Waste of money to go from 3/4" up to 1"?
What fittings should I look for?
Old 09-30-2016, 09:36 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 2,082
If you go with black poly, there are different ratings for pressure and I think temperature (up here anyway). If your currently have 2.5", using a smaller size may affect your available volume so larger would be better. Depends on your pump. There are fittings designed for poly, usually barb fittings and gear clamps.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
Old 09-30-2016, 09:47 PM   #5
Rewards Points: 44
Thanks. Temperature here is not likely to be an issue. The 2.5" was put there by a previous owner and the line was gravity feed only. I have since installed the pump. I see Advanced Drainage Systems blue 1" x 100' potable poly, rated at 200psi, at HD for only $40 so at that price, may as well go for it. The black 3/4" is only four dollars less.
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 11:33 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Big water leak under house Puzzles Plumbing 4 04-27-2011 02:50 PM
Poly Gasline to replace Black Pipe? GabeD Plumbing 9 08-29-2010 11:47 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
