PEX Options? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-26-2015, 11:09 AM   #1
Rewards Points: 42
PEX Options?
So, I'm finishing a bathroom in the basement and will be using PEX to feed the shower, toilet and single sink. House has copper tubing and I already stubbed out for PEX when I replaced the water heater last year (1/2 inch).
Is it okay to run a single 1/2 inch line and then use T fittings to drop to each fixture? Will I lose very much pressure from upstream pulls? The shower will be at the end of the run.
Thanks!
Coltabilly is offline   Reply With Quote
Old 08-26-2015, 04:24 PM   #2
Rewards Points: 1,938
Good practice is 2 fixtures on a 1/2 inch line.
Old 08-26-2015, 05:57 PM   #3
Rewards Points: 42
Thanks, but that is not what I wanted to hear... lol
Old 08-26-2015, 07:41 PM   #4
Rewards Points: 6,410
Test a length of your 1/2" pex for gallons / minute and see if the pressure you have will supply the demand.
Exploring Options ... dighog Electrical 6 07-28-2014 10:24 PM
Inexpensive Siding options that that aren't Vinyl or Metal GumbyMan Building & Construction 15 01-06-2013 11:01 AM
Recommendations for heating and cooling options for my home? daluu HVAC 2 12-23-2012 01:31 PM
Shower options Chilidog Tiling, ceramics, marble 3 06-06-2012 04:28 PM
Maytag dishwasher has 5 cycles and three options. only one cycle works and no options wwejj0926 Electrical 1 04-22-2012 05:54 PM
