PEX Joist Clamp - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2016, 01:22 PM   #1
siggy312's Avatar
Rewards Points: 64
PEX joist clamp
is there a "trick" to removing these with destroying the clamp and/or line.
SEE attached picture.
siggy312 is offline   Reply With Quote
Old 08-18-2016, 01:39 PM   #2
Rewards Points: 4,746
Re: PEX joist clamp
I would put a block next to it and use a hammer or prybar like any other nail. That said, I have found those clamps to be kind of fragile.
stick\shift is offline   Reply With Quote
The Following User Says Thank You to stick\shift For This Useful Post:
siggy312 (08-18-2016)
Old 08-18-2016, 02:51 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: PEX joist clamp
The clamp is a 25 item, grab the free end with pliers and twist it open. Move the pipe and pull the nail with a claw hammer.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
joists are pulling away from sill plate andrewjs18 Building & Construction 13 04-12-2015 12:48 PM
Cutting a 2" hole in several ceiling/floor joist in kitchen steppinthrax Building & Construction 21 12-01-2014 09:44 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
