Pex Insert Into Broken Main - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2017, 09:04 AM   #1
Rewards Points: 2
Pex insert into broken main
I have a broken water main between the wellhead and the house. the run is about 50 feet and break is about 10 foot from the well. It is old black poly pipe that has been in the ground at least 30 years. My problem is that the pipe goes under my driveway (which I have already cut and dug out to find the leak) then under a slab porch into the basement. The poly pipe is 7/8" ID so to temp fixed it I cut the broken section out, used a piece of 3/4" poly and inserted it into the removed section and pipe clamped the hell out of it to get water back to the house. Question is... Do you think I can insert 1/2" pex tubing into the original poly without much loss of flow. It is a typical well and expansion tank setup in a single family home. 2 1/2 bath and all the typical appliances. 2 adults and 2 kids 10 and older. Thinking 1/2" because its been in the ground so long it may be pushed down in spots and I don't think I could force through a 3/4 pex tube. Thanks!
goldendually is offline   Reply With Quote
Old 11-02-2017, 09:12 AM   #2
Rewards Points: 18,960
Re: Pex insert into broken main
You would end up with more than 1/2 the flow you have now.
Old 11-02-2017, 12:11 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 882
Get the same size poly and join with the barbed couplings.
Sent from my XT1095 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
Possible broken water main. Possibly urgent! Lemkie Plumbing 17 02-28-2014 06:00 PM
Joists, Sill Plate, Foundation and broken main beam Bonebag Building & Construction 14 02-03-2013 07:40 PM
50 amp sub panels from 100 amp main smithdavidp Electrical 10 12-31-2012 12:20 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
