PEX To Galvanized - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-05-2016, 02:39 AM   #1
Rewards Points: 1,414
PEX to galvanized
What is the right way to connect PEX to galvanized?
Have 1/2" galvanized, 1/2" PEX, want to connect the two.
The PEX threaded fittings appear to be brass, so I am guessing those can't be used on the galvanized without major corrosion problems.
Help?
Tom738 is offline   Reply With Quote
Old 06-05-2016, 03:50 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 18,160
Re: PEX to galvanized
The right way to connect?
Remove all galvanized. Anything else is just not going to turn our well.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Tom738 (06-05-2016)
Old 06-05-2016, 04:28 AM   #3
True. But in the interim...
Galvanized climbs underground up to the street, under driveways and walls and garages and such, which is an expensive non-DiY job that's not likely to happen for a few years unless it goes. So for now we need a reasonable way to transition to PEX once in the house.
Old 06-05-2016, 09:21 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 164
Help?
Brass and galvanized are fine together. Think of all the brass valves, including tub valves, used in galv. systems.
Use PEX x MIP or FIP adapters and get at it
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
ddawg16 (06-06-2016), rjniles (06-05-2016), Tom738 (06-05-2016)
Replacing Some Galvanized Pipe epsilono Plumbing 6 12-03-2015 07:53 AM
galvanized to pex to solve flow issues? jeffzap Plumbing 6 06-22-2014 11:37 AM
Original (?) galvanized water supply pipes replace with PEX, CPVC, copper? TomServo Plumbing 5 11-06-2012 11:07 PM
Sprinkler: Splice PVC onto older NONthreaded Galvanized? kronic24601 Landscaping & Lawn Care 0 02-13-2011 03:18 PM
firring out concrete wall for electric and insulation trouble Building & Construction 9 02-04-2009 11:40 AM
