PEX To Dishwasher? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-24-2016, 03:55 PM   #1
Rewards Points: 290
PEX to dishwasher?
Stupid question: I know in residential plumbing the dishwasher often just tee's off of the sink hot water.
If I already have a sink being fed by a 1/2" PEX, can I just tee off of that, or does it need a dedicated line?
gizzygone is offline   Reply With Quote
Old 03-24-2016, 06:46 PM   #2
Rewards Points: 582
Re: PEX to dishwasher?
Just tee off of that should be fine
Old 03-24-2016, 06:57 PM   #3
Rewards Points: 18,784
No need for a dedicated line, just make sure there's a Pex ball valve to shut the water off to the washer.
Old 03-24-2016, 10:43 PM   #4
Rewards Points: 114
Yes you can definitely tee off of the pex line, it's so easy. As mentioned before after you add the tee put a pex shut off valve to the dishwasher.
Chrisathome is offline   Reply With Quote
junction box location and acessibility for dishwasher JKeefe Electrical 10 01-19-2016 07:49 AM
Installing dishwasher, are dishwasher panels needed? Lemkie Kitchen & Bath Remodeling 4 02-24-2015 04:13 PM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
