Pen Drain Pipe In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 11-01-2016, 06:42 PM   #16
Rewards Points: 3,262
Re: Pen drain pipe in basement
Radon originates in the ground. So it is quite common for a sump pump system to double as a radon collecting system.
The pit is covered so the radon exhaust pump will draw more radon laden air from the perimeter drain pipes as opposed to exhaust large quantities of furnace heated air or air conditioner cooled air from the basement at large. Also to reduce the evaporation of water from the pit so as to increase the load on the basement dehumidifier.
The radon exhaust pump may be located at the upper end of the vent pipe rather than down at the pit.
Ground water going to the sump pump pit, where the quantity of such water will be increased when it rains, must not be pumped into a septic tank. So it is rare to have the basement perimeter drain pipes emptying into the same pit that receives sewage or gray water.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
k_pradeep (11-05-2016), lenaitch (11-01-2016)
Tags
basement , drain , pen , pipe , sump
frame around verticle drain pipe - basement fenders Remodeling 4 01-26-2012 03:15 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 07:51 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Framing basement wall with drain pipe owais Remodeling 13 03-25-2009 09:48 AM
