Pen Drain Pipe In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree2Likes
Old 10-29-2016, 09:55 PM   #1
Question
Pen drain pipe in basement
Hi, can any one please explain what pen drain pipe is? I have two pipes going into sump in my basement. One is Radon and another is Pen drain. I couldn't get any information about pen drain pipe in internet. Please see the attachment for the photo.
k_pradeep is offline   Reply With Quote
Old 10-29-2016, 10:30 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,720
Re: Pen drain pipe in basement
No idea what a Pen drain is. Where does it come from? I'm not that familiar with radon systems but as I understand it they don't normally go into a wet drain - they extract air from below the pad and exhaust it outside. Are you sure the pipe (hidden behind the dehumidifier) goes into the sump? Also, that doesn't look like a sump drain but more like an ejector pump. Sump drains are usually open (although they may be covered) and used to extract ground water. Ejector pumps are normally sealed and used to eject grey water and sewage.
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
k_pradeep (10-30-2016)
Old 10-30-2016, 07:41 AM   #3
Rewards Points: 18,768
Follow the drain to see if it goes to something like a water softener or air exchanger.
Old 10-30-2016, 11:21 AM   #4
@lenaitch , Thanks for the reply, I could not able to find the source of this pipe but I guess it may going some where up of the home. It could be as you said to extract and pump air to up.
Old 10-30-2016, 12:38 PM   #5
Rewards Points: 80
Can we get more pictures. Particularly without the humidifier in the way.
Radon mitigation essentially sucks the air from under your slab and exhausts it outside. There's more then one type of setup. Just FYI, for anyone reading.
As for the pen drain, do you have any areas around your house that's below sewer level?
Go around pouring water down drains until a helper hears the sound in that pipe. Run out of drains? Move on to roof vents. My first guess would be something lower then sewer grade though.
Cheers!
supers05 is offline   Reply With Quote
Old 10-30-2016, 08:31 PM   #6
Usually Confused
lenaitch's Avatar
I am guessing that the "radon" line goes through your floor near the sump/pump well but actually has nothing to do with it. It should exhaust out an exterior wall and should be easy to trace. I don't know if there is a fan or blower involved or if they are simply a venting system. It is the "pen drain" that might be helpful to trace and some other posts have offered suggestions on how to do that.
Old 10-30-2016, 09:44 PM   #7
Rewards Points: 3,268
How did you hear about the term "pen drain"?
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
AllanJ is online now   Reply With Quote
Old 10-30-2016, 10:08 PM   #8
Usually Confused
lenaitch's Avatar
It's written on the left-hand pipe in the OP photo. So far, nobody seems to know what it means.
Old 10-30-2016, 11:27 PM   #9
Rewards Points: 80
It could be a more literal label.... A drain for a penned area... Or if a Den (bad penmanship?) that has a bar sink. Etc.
Cheers!
Old 10-31-2016, 06:23 PM   #10
Rewards Points: 1,852
Maybe its a pan drain for a washer machine. Your plumber flunked spelling.
lenaitch and supers05 like this.
The Following User Says Thank You to Ghostmaker For This Useful Post:
k_pradeep (11-01-2016)
Old 11-01-2016, 05:50 AM   #11
@Ghostmaker , may be my plumber flunked. I attached more pics. Pipe is going some where up.
Pen drain pipe in basement-img_7571.jpg   Pen drain pipe in basement-img_7572.jpg
Old 11-01-2016, 05:59 AM   #12
@supers05 , I am seeing my sewer pipe is higher than the basement ground.
Old 11-01-2016, 06:00 AM   #13
@lenaitch , please look at my new picture. this pipe is going down.
Old 11-01-2016, 06:07 AM   #14
Rewards Points: 80
All that clears up is that you apparently have a passive radon system with a ejector pump using the same pit.
You have a unique build. Have you asked the builder?
Cheers!
Old 11-01-2016, 04:38 PM   #15
Usually Confused
lenaitch's Avatar
As I mentioned above, I know virtually nothing about radon systems and it seems others think that the two systems sharing a pit is possible, if not a tad unusual.
I only assumed it was an ejector pump (sealed) as opposed to a sump pump (unsealed) since it looked like it from the photo viewed on a laptop. If it is an ejector pump, it needs to be vented, so perhaps that line is a vent. All of that said, it seems that we have not been able to answer your question about the cryptic label.
Tags
basement , drain , pen , pipe , sump
frame around verticle drain pipe - basement fenders Remodeling 4 01-26-2012 03:15 PM
Adding a basement floor drain for A/C Condensor SuzieSawzall Plumbing 9 03-28-2011 07:51 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Framing basement wall with drain pipe owais Remodeling 13 03-25-2009 09:48 AM
