PB Pipe A Problem With Non-municipal Water? - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree1Likes
  • 1 Post By joed
Old 11-14-2017, 03:58 PM   #1
Rewards Points: 6
Question
PB pipe a problem with non-municipal water?
The home I just purchased "in the woods" has PB water pipes. Since I have my own well (no chlorine or chloramine), is there any need to replace the PB pipe?
pbgvdad is offline   Reply With Quote
Old 11-14-2017, 04:24 PM   #2
retired framer
Rewards Points: 15,346
Re: PB pipe a problem with non-municipal water?
I have never heard of anyone anywhere around where I am that has had a problem.
Old 11-14-2017, 04:29 PM   #3
47_47's Avatar
Rewards Points: 320
Your guess would be as good as anyones.
PB pipe had a lawsuit back in the 90's for leaks developing in the pipe. The leaks were attributed to water additives such as chlorine. You may be ok being on a well. I'd hire a plumber / inspector for an on-site review.
47_47 is offline   Reply With Quote
Old 11-14-2017, 04:36 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,946
PB info from the home inspectors site.
https://www.nachi.org/pb.htm
47_47 likes this.
Tags
pb pipe replacement , well water
Chasing Ghosts - Phantom Water Leak FrozenMeatballs Plumbing 7 10-29-2014 06:03 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 07:18 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
