P-trap Under Bathroom Sink Not Lining Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-27-2016, 09:18 AM   #16
Rewards Points: 16
Re: P-trap under bathroom sink not lining up
Completed! Looks a bit pretzel-like, but I like pretzels.
Seems to work fine so far (note the pop up hole is above the wall pipe, so I don't think there will be any drain issues with that.
Thanks for the tips!
Sensei is offline   Reply With Quote
The Following User Says Thank You to Sensei For This Useful Post:
jmon (05-31-2016)
Old 05-31-2016, 07:31 AM   #17
Rewards Points: 1,328
Accordion tail piece from the sink to the trap would have been the easiest. I used one for 10 yrs and was surprised how clean it kept. Other houses and one personal experience was opposite. But flex can work.
carpdad is offline   Reply With Quote
Old 05-31-2016, 03:23 PM   #18
Rewards Points: 16
I tried that first @carpdad , but everyone blasted me here and another forum
But thanks!
Old 05-31-2016, 05:06 PM   #19
Rewards Points: 1,866
Dude that looks like a pro did it.. Good JOB!
The Following User Says Thank You to Ghostmaker For This Useful Post:
SHR Plumber (06-01-2016)
Old 06-01-2016, 09:50 PM   #20
Rewards Points: 38
NO. Just NO.
Unless one of my clients is interested in buying your house. Then we get an allowance from you, the would-be seller, to re-plumb the home due to really bad, not to mention not code compliant existing plumbing. Any time "accordian" type tubing is found, my clients have always negotiated multi-thousand dollar discounts in order to pay to have the plumbing re-done.
SHR Plumber is offline   Reply With Quote
The Following User Says Thank You to SHR Plumber For This Useful Post:
rjniles (06-02-2016)
Old 06-04-2016, 07:27 AM   #21
My wallets in my pants pocket therefore thats hitting below the belt. Lets follow the rules.
Old 12-01-2016, 04:03 PM   #22
Rewards Points: 6
Hi, all. Noob here to the forums. Question on this picture. I have a similar dilemma and I'd like to know the parts terminology so I buy the right thing. It looks like (From the wall) Trap adapter --> Some slip joint extension --> Slip joint 45 elbow --> Trap arm --> J-trap, etc. The items in red (both in text and picture) are what I need for mine to work, and I want to know what to buy. The angle on my drain in the wall is a bit extreme and I need to bring it out a little.
Thanks!
Vic
(will post a pic shortly once I'm allowed)
Victor D is offline   Reply With Quote
Old 12-01-2016, 04:49 PM   #23
Rewards Points: 6
These are the parts I need. Proper names of these?
The one in the back needs to screw on to the male threads on my 1-1/2" trap adapter coming out of the wall
Tags
lining , p-trap
Bathroom sink overflow Steve97 Plumbing 3 03-01-2016 08:39 PM
Bathroom sink drain p trap daveplot Plumbing 1 05-25-2013 10:01 AM
Swivel PVC P trap for bathroom sink. pinecone12 Plumbing 9 06-06-2011 09:14 AM
bathroom sink stopper question - Pictures in thread amodoko Plumbing 5 05-31-2011 05:24 PM
add second bathroom sink - tap into original denemante Plumbing 1 03-22-2011 12:21 AM
