P-trap Under Bathroom Sink Not Lining Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-17-2016, 04:03 PM   #1
Rewards Points: 16
P-trap under bathroom sink not lining up
I got new countertops and my P-trap is not lining up. What solutions can I do to fix this? I have read to stay away from flexible P-traps, but this is the only solution I see right now, unless I can find a 45* bend that is only threaded on one side (the pipe at the very wall exit is threaded) and I can take the straight wall pipe out, put that 45 on and cut the straight and then flip the p-trap so it faces towards the wall, but not sure that'll line up either...
Thanks!
P-trap under bathroom sink not lining up-img_0545.jpg   P-trap under bathroom sink not lining up-img_0581.jpg   P-trap under bathroom sink not lining up-img_0582.jpg   P-trap under bathroom sink not lining up-img_0583.jpg
Sensei is offline   Reply With Quote
Old 05-17-2016, 05:21 PM   #2
An old Tradesmen
Rewards Points: 9,200
Re: P-trap under bathroom sink not lining up
Moved to Plumbing forum.
Old 05-17-2016, 06:56 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Tubular slip joint 45 elbow.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following 2 Users Say Thank You to rjniles For This Useful Post:
gregzoll (05-17-2016), oh'mike (05-17-2016)
Old 05-17-2016, 08:40 PM   #4
Rewards Points: 16
I have one, but where does it go? The only thing I could think might work is if I remove the straight pipe from the wall and put the 45 at the wall, then the straight and shorten it, then flip the P trap around so it faces the wall side. The only problem is, the pipe at the very wall side is threaded, as is both sides of the slip joint. I'm not finding a one-sided threaded slip joint 45* and the other side clean. Or, I don't know how to connect 2 threaded pieces together?!
The other sinks were fine.
Old 05-17-2016, 08:52 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Cut a short piece (about 2") of tubular pipe and use it to connect the 45 to the trap adapter. That will let you connect the trap to the 45
Old 05-18-2016, 08:50 AM   #6
Rewards Points: 16
Question
So you're saying I'd have wall pipe (I think that's called the trap adapter) which is threaded, a 2" piece of unthreaded pipe, then the 45* elbow (threaded both sides), then the other side of the angled wall pipe (~2") to go down to the P-trap which will be rotated probably backwards more?
Otherwise, I don't understand how I can attach the threaded 45* elbow to the threaded trap adapter at the wall - see my pic.
Thanks!
Old 05-18-2016, 11:45 AM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Yes the threaded piece coming out of the walk is the trap adapter. Cut the elbow coming out of the wall in your first picture and leave a 1.5" stub from the wall. Connect the 45 to that.
Old 05-18-2016, 03:53 PM   #8
Rewards Points: 16
Got it! Thanks for the help
Old 05-20-2016, 07:38 AM   #9
Rewards Points: 1,602
Could he also do a 90 coming out of the wall facing left and then face the trap straight back? Then he would just need the appropriate distance from the wall for the 90 and it will line up. Probably less elegant and more bends, but would that be allowed?
mikegp is offline   Reply With Quote
Old 05-20-2016, 07:50 AM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Would you want to snake that?
Old 05-20-2016, 08:29 AM   #11
Rewards Points: 16
Wouldn't you need 2 90s? One 90 would then put the pipe parallel with the wall and couldn't connect the p-trap or straight pipe to that.
I think frodo's suggestion is the best. Will try that this weekend, if I have time!
Old 05-20-2016, 09:28 AM   #12
Yes, that would be two 90's. Didn't sound like a great idea.
Please post up a pic of your final product.
Old 05-24-2016, 03:24 PM   #13
Rewards Points: 16
I'm back. I got strep and it hit my muscles weird and rendered me useless for a week.
OK. I cut a short piece, then my 45*, now I'm stuck again! The only solution I see is to flip the P-trap around and cut a very short angled down pipe section to go on the 45* (see pic, it's a bit tilted but that's just how I was holding it).
Anyone see another solution?
I can't slide the P-trap up any higher because it hit the stopper horizontal nub out of the tailpiece. So the angled down pipe won't reach. Cutting that tailpiece wouldn't do me any good then.
Thanks again..
P-trap under bathroom sink not lining up-img_0615.jpg   P-trap under bathroom sink not lining up-img_0616.jpg
Old 05-24-2016, 04:07 PM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Not sure what you are describing but he ere is mine.
Old 05-24-2016, 04:49 PM   #15
Plumber
TheEplumber's Avatar
Rewards Points: 162
Your drain at the wall is too high.
Your solutions are to lower the drain, which means cutting into the wall and drain line.
Or find a shorter pop up drain assembly for the sink.
Solution 2 is the easiest.
Tags
lining , p-trap
Bathroom sink overflow Steve97 Plumbing 3 03-01-2016 08:39 PM
Bathroom sink drain p trap daveplot Plumbing 1 05-25-2013 10:01 AM
Swivel PVC P trap for bathroom sink. pinecone12 Plumbing 9 06-06-2011 09:14 AM
bathroom sink stopper question - Pictures in thread amodoko Plumbing 5 05-31-2011 05:24 PM
add second bathroom sink - tap into original denemante Plumbing 1 03-22-2011 12:21 AM
