P-Trap Retrofit - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-26-2015, 01:35 PM   #1
Rewards Points: 28
P-Trap Retrofit
I just remodeled our small first floor half bath. Along with new tile, paint and toilet, I installed a new vanity and sink. Of course the drain on the new sink did not line up with the p-trap, it was about 1.5" off, so I had to do some minor modifications.
Right now everything is dry fit, but before I secure everything, I wanted to post a couple photos and see if what I did was done properly and if known, up to Calif code.
Here is the breakdown:
- 1.5" male threaded p-trap adapter coming out of the stub out from the wall
- 1.5" ABS female adapter screwed to p-trap adapter
- 2 x 1.5" 45 degree street elbows attached to the slip end of the female adapter (to compensate for the 1.5" offset)
- Male adapter connected to female end of 45 degree elbow (glued, with a short piece of ABS pipe)
- P-trap then connects to that via water tight coupling then to drain.
Thx...
pd417 is offline   Reply With Quote
Old 07-26-2015, 02:07 PM   #2
Retired Moderator
Rewards Points: 7,174
Looks goofy, but I believe that will work just fine---
I assume the P-trap will not go directly into the old trap adapter in the wall--
pd417 (07-26-2015)
Old 07-26-2015, 06:18 PM   #3
Rewards Points: 28
That's correct. Originally it did, but with the drain not lining up with the p-trap, I had to use the 2 45 elbows.
Old 07-26-2015, 06:28 PM   #4
Retired Moderator
I moved this to 'plumbing' for you---
Old 07-26-2015, 07:14 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 876
I would come out of the original trap adapter and use tubular fittings. The make a 45 degree.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Disposal to P trap Jamesonc Plumbing 16 12-05-2014 03:46 PM
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
