P-trap Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2016, 05:37 AM   #1
Rewards Points: 379
P-trap problem
Putting in new vanity when found a p-trap problem.
My sink drain pipe is too close to the PVC drain on the wall.
See picture please.
Current p-trap COULD be cut to fit but it would have to be so much of a cut that there would be no straight portion of p-trap pipe going into adapter.
What are our options? Cut the PVC behind adapter and cement in new adapter?
Zamboknee is offline   Reply With Quote
Old 06-13-2016, 05:49 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
Re: P-trap problem
Cut the wall pipe shorter and install a new trap adapter.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 06-13-2016, 08:25 AM   #3
Rewards Points: 18,760
Re: P-trap problem
Your missing the escutcheon plate anyway, and the pipe would need to be cut to get it on.
That tail piece on the sink can also be cut shorter if needed.
SHR Plumber (06-13-2016)
Phorid Fly problem - tried everything - desperate for help! ALS2259 Pest Control 54 10-10-2018 02:31 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
