P-Trap Position - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-24-2016, 10:16 AM   #1
siggy312's Avatar
Rewards Points: 64
P-Trap position
see attached picture. Is this OK (code)...?? Will I have issues...??
The Sani Tee location coming out of the wall is quite high.
NOTE: I still can ensure there is the proper slope.
siggy312 is offline   Reply With Quote
Old 07-24-2016, 11:50 AM   #2
Rewards Points: 1,860
Re: P-Trap position
Yes. You have no room for the popup assembly. Not to mention you will end up having a 6 inch deep trap that will love accumulating stuff.
So lower the sanitary TEE.
The Following User Says Thank You to Ghostmaker For This Useful Post:
siggy312 (07-24-2016)
How to replace furnace drain trap burnzyd HVAC 2 04-07-2012 09:26 AM
Would this be a 'P' trap or an illegal 'S' trap? klondiker Plumbing 7 04-06-2012 10:18 PM
Basement Trap and confused questions Ryan7 Plumbing 15 02-26-2011 10:42 AM
p trap problem chrishulett Plumbing 8 01-28-2011 05:52 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
