P Trap Leak At Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2019, 03:41 PM   #1
Rewards Points: 469
P Trap Leak at gasket
I just installed a new P trap kit. This also includes a new pipe from the trap into the waste line in the wall.
Problem: The 1 1/2" pipe that curves down & attaches to the trap has a very slight leak. I found that somehow the gasket that seals the trap to the pipe developed a split & was cracked in half. I replaced the gasket with a heavy duty rubber gasket made for the job. I still have a very very minor leak, but still it is a leak. Since these connections are generally made only hand tight, I don't want to damage anything by over tightening.
I know its basic, but how do I stop this leak. All the other connections from the sink tailpipe, the adapter into the wall connection, the trap to the tailpipe connection are all working with no leaks. The only leak is from the trap on to the curved connection end of the pipe. Any suggestions. I'm not a plumbing experienced guy when it comes to leaks. Thanks.
maddog1 is offline   Reply With Quote
Old 03-25-2019, 03:51 PM   #2
Rewards Points: 496
Re: P Trap Leak at gasket
If itís leaking where I have it circled there is no gasket that goes there
BayouRunner is offline   Reply With Quote
The Following User Says Thank You to BayouRunner For This Useful Post:
maddog1 (03-26-2019)
Old 03-25-2019, 03:59 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 428
Replace the trap and wall pipe. They cost less than $5.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 03-25-2019, 04:01 PM   #4
Property Mgt/Maint
Rewards Points: 6,042
If you have a rubber gasket then must be a metal trap. It's OK to snug it up with a pair of channel lock pliers.
[political signature removed]
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 03-26-2019, 09:38 AM   #5
Rewards Points: 469
Yes. Where you have it circled is my leak. I will remove the gasket & see what happens. It's a little confusing to me, because all my other drain traps have a plastic gasket under the nut, it the same place as you circled. I nee to take a closer look at the other installations & see If I find what makes the difference (gasket-no gasket). Thanks. I will try your fix!
Maddog1
Old 03-26-2019, 09:54 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 428
On a PVC trap there is never a drain washer at that joint.
Sent from my Moto E (4) Plus using Tapatalk
Old 03-26-2019, 10:16 AM   #7
Property Mgt/Maint
Clarify for us whether you have a PVC or metal trap and trap arm.
Old 03-26-2019, 03:51 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 428
He posted a pix of a PVC trap.
Old 03-26-2019, 04:18 PM   #9
Property Mgt/Maint
yes I see your point but the op didn't post the pic first. He just referenced it for location of his leak.
Unless I am missing something. I don't see anywhere he suggests his trap is PVC
Old 03-27-2019, 10:12 AM   #10
Rewards Points: 44
Back to the Op - (assuming PVC) make sure everything is aligned and fits without stressing before tightening.
tribe_fan is offline   Reply With Quote
Using Refrigerant for Leak Test instead of Nitrogen! Dangerous??? DIY AC GUY HVAC 19 08-16-2018 09:10 PM
Faulty toilet bowl? New toilet, gasket leak Fritzav Plumbing 3 10-23-2013 03:25 PM
1993 chevy tbi gasket leak HEVYD13 Automotive Repairs 1 03-31-2011 07:41 PM
Apartment water leak - questions haris General DIY Discussions 2 03-23-2011 07:26 PM
Trap Adapter Leak? kcrossley2 Plumbing 6 01-27-2010 12:55 AM
