P Trap Delima - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 01-25-2017, 04:27 PM   #16
Rewards Points: 1,942
Re: P trap delima
See how that chrome pipe is attached in the wall. If it can be removed and you may be able to screw a PVC MIP into it if a female threaded adapter is on the other end of that chrome tube. Then run a glue trap in schedule 40 pvc.
Old 01-25-2017, 04:33 PM   #17
Rewards Points: 106
Re: P trap delima
Its lead soldered. I'm going to pull the outside cedar, cut and replace!
rjniles likes this.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-26-2017, 01:07 PM   #18
Rewards Points: 106
New issue
So it appears the bottom pipe is a lead pipe of some unknown size! The upper has an outside diameter, per digital caliper, of 1.65 inches. So I am assuming it's 1 1/4 pipe?
So based on this pic, how do I get the lower pipe out of the cast iron and how do I, if you can, secure replacement pvc in the cast iron?
As usual, rotate pic clockwise one turn!
Old 01-26-2017, 01:13 PM   #19
Rewards Points: 6,468
Re: P trap delima
My retirement motto is: " just do whatever is fun and irresponsible ". This rotating pictures is just a little too responsible but enough fun to over rule that irresponsible decision.
That was put together with a gasoline blow torch. You may not be able to find one to take it apart.
Old 01-26-2017, 01:38 PM   #20
Super Moderator
joed's Avatar
Rewards Points: 31,970
Re: P trap delima
Support the upper cast iron pipe. Cut below the sink t connection. Remove cast up to bell connection. Use no hub rubber fittings to insert a section of abs pipe with your new sink stub out.
sort of like this image only cast iron instead abs and go through wall instead of sideways through stud unless you also want to move the drain sideways.
MTN REMODEL LLC likes this.
The Following User Says Thank You to joed For This Useful Post:
digitalplumber (01-26-2017)
Old 01-26-2017, 04:03 PM   #21
Rewards Points: 106
Re: P trap delima
Problem resolved. Took a steel rod, inserted it into the drain and lifted. The soft lead easily moved without issue or leak. Connected p trap and allwas well.
While I did not get to do as pictured above, at least it is functioning now.
Old 01-26-2017, 07:51 PM   #22
Re: P trap delima
I got to ask how old is that house? Lead pipe on a lav drain highly unusual in Cleveland area. We usually have cast iron with solder collars or copper or threaded galvanized piping on lav drains.
Old 01-26-2017, 08:38 PM   #23
Rewards Points: 106
Re: P trap delima
Best guess,late 50's early 60's.
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
