P Trap Delima - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
Old 01-24-2017, 02:33 PM   #1
Rewards Points: 106
P trap delima
In the attached pic I need to connect the sink drain to the wall drain with a p trap. But as you can see, the base/shelf above the drawer makes the p trap too high to meet.
Short of cutting up the shelf, can anyone offer an alternative?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-24-2017, 02:34 PM   #2
Rewards Points: 106
Re: P trap delima
And yes it's loaded upside down!
Old 01-24-2017, 02:50 PM   #3
Rewards Points: 6,472
Re: P trap delima
Rotated 180. Hopefully it stays that way.
MonsieurBon likes this.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
digitalplumber (01-24-2017)
Old 01-24-2017, 03:02 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,970
Re: P trap delima
Three options as I see it.
1. Raise pipe in the wall.
2. Lower the shelf
3. Cut hole in shelf.
The Following User Says Thank You to joed For This Useful Post:
Old 01-24-2017, 03:10 PM   #5
Rewards Points: 106
Re: P trap delima
I guess a low profile p trap offers no assistance here?
Old 01-24-2017, 05:47 PM   #6
Rewards Points: 18,974
Re: P trap delima
Normal drain height should have been about 21" above the finished floor, what's yours?
Old 01-24-2017, 05:54 PM   #7
Rewards Points: 106
Re: P trap delima
Will get that measurement tomorrow,when I return to my sons home.
Old 01-24-2017, 06:26 PM   #8
Property Mgt/Maint
Rewards Points: 8,202
Re: P trap delima
The tubular drain stub out looks like it is corroded and broke apart.
Yodaman is offline   Reply With Quote
Old 01-24-2017, 06:41 PM   #9
Re: P trap delima
A simple tubing cutter can make that stub shorter.
Old 01-25-2017, 01:53 AM   #10
Rewards Points: 80
Re: P trap delima
2. Lower the shelf
Locally change the laws of gravity so water can flow up hill, if we desire.
It's been a long day.... Lol.
Cheers!
supers05 is offline   Reply With Quote
Old 01-25-2017, 07:01 AM   #11
Rewards Points: 106
Re: P trap delima
Yes the stub out will need to be cut back.
I saw an "s" trap setup that may work?????
Old 01-25-2017, 07:15 AM   #12
Property Mgt/Maint
Re: P trap delima
FWIW, code requires a P-trap.
Since the end of the stub out is corroded and broke, what shape is the other end in?
Now might be a good time to fix all of it by raising the stub out so the shelf is not a issue. Also extend the stub out so the adapter is on this of the wall so you could change it next time with out breaking into the wall.
Old 01-25-2017, 07:27 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
Re: P trap delima
S traps do not meet code. Raise the trap arm.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
digitalplumber (01-25-2017)
Old 01-25-2017, 07:41 AM   #14
Rewards Points: 106
Re: P trap delima
Links to online video or instructions for replacement would be nice.
Old 01-25-2017, 08:22 AM   #15
Rewards Points: 106
Re: P trap delima
I have been upset about tearing everything out to do this, but I just realized I can do this from the outside wall!
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 06:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
